Hi. I think you need some different weights to get the right calculation.
You need your TV alone (got that, 6760 - which is a combination of your steer plus your drive axle - what are those numbers?) then you need your TV and TT across the scales without any WD applied (this will give you 3 numbers - TV steer - which will be lighter than TV steer alone because of the tongue weight, TV drive which will be heavier because of the tongue weight, and trailer axles), then your final pass is TV with TT connected and full WD applied - this will now show you how much of your TV steer loss was restored and how much was pushed off your TV drive axle to your TT axles (which will now be higher with WD applied).
From there you can calculate tongue weight.
I'll see if I can find a link to the threads that cover this in great detail - but try the search function for "cat scales" or "how do I weigh my trailer" and see what you come up with. Good luck!!
