Here is a rundown on what has been accomplished.
Deck repaired. Section of rear bath and entry door deck replaced. Floor deck is solid as a rock.
New torsion axels, shocks, rims and Michelin trailer rated tires installed. Trailer sits nicely now and should ride like new.
Black water tank removed and inspected.
Dump valves rebuilt.
All plumbing replaced with PEX and hot and cold drains added to make it easy to clear lines and winterize.
Gas lines replaced.
Hot water heater replaced with dual LP and electric model.
Trailer pig tail replaced and all connections housed inside an electrical box up under the belly pan.
Frame inspected and new belly pan installed.
Subfloor laid for flooring.
Bathroom primed.
New progressive Dynamics Mighty Mite 60 amp service and battery charger installed.
Battery connections replaced. Planning to install multiple
12V batteries.
New license plate holder/light purchased.
New radio antenna purchased. Love the OEM Motorola radio. I'm hopeful I can use a patch cord to run my smart phone thru it as a source.
A number of things have been ordered and will be arriving soon.
These include:
Cork flooring from ICork. Silver birch pattern 6 mm thickness. It is a light attractive color, soft under foot, insulates, and withstands contact with water very well.
New Command Air 15,000 BTU A/C and electric heat pump.
New Suburban 22" LP match light range. Went with match light ignition to avoid issues with electronic ignition.
Elkay 21" 18 ga undermount sink with lustertone finish.
Kohler Simplicity kitchen faucet.
Decided to go with butcher block kitchen counters.
Having black walnut from my farm made into a new bathroom counter and dinette table. Bath cabinets will be maple with spalted maple cabinet doors.
Bath sink will be white counter top vessel type with Kohler Archtype faucet.
Porcelain toilet.
Interior walls will be Benjamin Moore Simply White.
30 gallon aluminum propane tanks purchased.
Crypton chenille upholstery fabric purchased to redo seat cushions.
Still looking at sourcing curtains.
In process of getting bids for exterior paint.
Attached is a pic of the upholstery fabric. Went with a dark color for a bold contrast with the white walls and to tie in both the existing faux walnut factory cabinets and the real wood I am bringing into the interior. The lighter tones will tie in the floor and butcher block counters. Going for a un updated Zen Spa look...lol.
Prices for the major items varied widely from retailers. I researched quite a bit to find what would be best for my application. Then I shopped suppliers. I could have easily spent 40% or more for many of the larger items. It pays to shop around.
