Old 05-29-2018, 06:56 AM   #1
1976 Argosy 28
San antonio , Texas
What's the switch for
Just inside the doorway on your right as you come in are two switches. The first operates the outside light above the door. What does the second switch do? It doesn't seem to turn anything on or off. The large round light on the side of the trailer I need to replace the bulb. Is the switch for that?
Thanks...
Whit461 is offline   Reply With Quote
Old 05-29-2018, 07:02 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
On my 75 TW it was part of the 3 way switch circuit for the light over the sink.
Richard
azflycaster is online now   Reply With Quote
Old 05-29-2018, 08:28 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I've see the second switch by the door either operate a light in the kitchen area or the light that is in the combination fixture with the fan.
To find out which light is controlled by the switch, turn on the lights with the knob or switch on the fixture itself. Then operate the switch by the door to see which fixture goes off. If that switch does not control anything, the switch might be bad or the wiring has been modified.
Inside the fan/light fixture there are two wires supplying power. One is from the switch to the light. The other is for power to the fan. I've see those wired incorrectly, using just the fan power wire for both light and fan, leaving the switch inactive.
Alan
Old 05-29-2018, 09:08 AM   #4
1999 30' Excella 1000
small town , Maryland
I have the same problem. Thanks for the thread and responses. Can you get the same replacement switches at any RV store.
streaminwild is offline   Reply With Quote
Old 05-29-2018, 09:23 AM   #5
Mollysdad's Avatar
Thanks...
Mine is a light on the step.
Old 05-29-2018, 10:12 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Very often, that second switch is for the step light which could be burned out.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 05-29-2018, 11:52 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I missed that part about the round exterior light in post #1. That was not an original light option. When it was added it is a good possibility that the switch was used to control that light. (Google 'scare light' - there are some LED fixtures that will fit exactly in that round hole)
On a 1976 Argosy, the light over the door was not standard equipment, it was an option.
A step light was not offered at all, standard or optional. If there is one it was also added.
This is a link to the sales specifications for your trailer.
https://www.airstream.com/wp-content...80fc148908.pdf
This is a link to the standard and optional equipment list.
https://www.airstream.com/wp-content...3fd95cc34e.pdf
This is a link to a 1976 Owners Manual.
https://www.airstream.com/wp-content...0110i.arc_.pdf
Alan
Old 05-29-2018, 12:07 PM   #8
1976 Argosy 28
San antonio , Texas
So at lunch, I put a new bulb in the scare light and turned on the switch. Nothing. Turned on all the interior lights and flipped the switch. Nothing. I need to put two bulbs in the front piece over the front window, but nothing went out with the switch. Tonight after work I'll check with my tools for power to the switch, scare light, etc.
Old 05-29-2018, 12:11 PM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Out of Doors Mart has some switches. You might check to see if they have one like yours.
This is one example:
http://odmrv.com/catalog/index.php?m...roducts_id=672
Alan
Old 05-30-2018, 01:18 PM   #10
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
On my 75 MH both were for outside lights. The bulb socket may be corroded so even a new bulb won’t work. On my 71 GT it Was a 3 way to kitchen light, but the light was only connected to one switch leg. It had been tampered with. The switch contacts can also get corroded. I would look at the bulb socket first.
bibbs is offline   Reply With Quote
Old 05-30-2018, 04:11 PM   #11
2018 28' Flying Cloud
Ammon , Idaho
ON our 2018 FC, the second switch is for the LED lights under the awning.
Commish is offline   Reply With Quote
Old 05-30-2018, 07:19 PM   #12
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
You are on the right track. On my 77 argosy one switch is for the scare light and the other one is for the light above the door.
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 05-30-2018, 07:28 PM   #13
Iron tepee #35
1993 34' Excella
andalusia , Illinois
Is there a light up from you the propane tanks?
mikeoxlong is offline   Reply With Quote
Old 06-07-2018, 06:41 PM   #14
1973 Argosy 22
Gold Hill , North Carolina
On my 73 22ft Argosy, that switch turns on the round light on the outside beside the door. It is a bright flood light.
n89217 is offline   Reply With Quote
Old 06-08-2018, 09:02 AM   #15
1976 Argosy 28
San antonio , Texas
I think so. Right now the switch itself is dead. No power getting to it,and the scare light is also dead, so I have a dilemma: do without and stop worrying about it, or open up the wall and trace wires. Thanks, I think you are on the right track.
Old 06-08-2018, 09:21 AM   #16
1978 Argosy 27
Elk Rapids , Michigan
So, put some power to it and see if the light will come on. It's more likely disconnected near the exhaust fan then a broken wire in the wall.
matthewsx is offline   Reply With Quote
Old 06-08-2018, 02:06 PM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by A W Warn View Post
I missed that part about the round exterior light in post #1. That was not an original light option. << snip>>]
^^ For the record, this statement I made is wrong.^^
The round scare light was an option, as part of the "Safety Group" package.
Sorry, for posting incorrect info!
Always learning!
Alan
whats this switch? next to storage kill switch. Looking4air Electrical - Systems, Generators, Batteries & Solar 1 06-28-2013 01:59 PM
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
Light Switch (Wall Switch) for 69 Overlander mbmbstreamer Lights - Interior & Exterior 3 03-21-2010 04:39 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
“Appliance selector switch” TRAPEZE Airstream Motorhome Forums 7 07-30-2002 05:32 AM
