RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-17-2019, 03:10 PM   #321
wcronin4's Avatar
1978 31' Sovereign
New Smyrna Beach , Florida
Continued from the previous posting
A total of five patches were created and installed. Using Alclad .032, a jigsaw, a grinding wheel and sanding block I did my best to create something that didn’t look like a drunk had made it. Except for the pics already shown, the following pics are the result. Using suggestions from David and Kay, I used Vulkem between the patches and the skin and, on the inside, I sealed all the bucked rivets. About half done, and no leaks.
The red and blue decals running back from the “International” badges are brittle, faded, cracked and stubborn.
I flailed around on the internet looking for something I could use to remove them that would not scratch the aluminum. I found a product called “3M Decal Eraser Wheel,” that attaches to a drill. I gave it a test-drive. It works like a champ. The residual you see in the pics below should come off with Goo-Gone or something similar.
Work continues on sealing up. The next major project is installing belly pans, banana panels, and side panels. Big job. On my back. Fun!
Bill
Keeping Faith
____________________________________
My Project thread
https://www.airforums.com/forums/f22...ff-191141.html
wcronin4 is offline   Reply With Quote
Old 10-17-2019, 08:32 PM   #322
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You have bee busy! It is very good to "test for leaks" in a Florida downpour. Those dang vista windows are more problems than they are worth. I'm happy my Overlander doesn't have them. I tried the 3M decal remover wheel and didn't have much success on our Limited. I did find Aircraft Stripper bubbled up the old vinyl decals quite well.
The belly pan project is hard work, but you can do it. Just take your time with it.
David
WBCCI #8607
VAC Region 11
See my 1966 Trade Wind Renovation Documentation:
Knowledge Base Airstream Trailers
See my 1975 Overlander Improvement Journal:
See our 1976 Sovereign Renovation Project:
Old 10-18-2019, 02:34 PM   #323
wcronin4's Avatar
1978 31' Sovereign
David
Was the Aircraft Stripper you used fairly current, or a supply you’ve had for a while? Guy at the local auto paint shop warned me that the stripper they sell today has been stripped of the more effective chemicals by EPA. No pun intended.
All of my belt pieces need to be stripped of paint. So I need something that really works.
Bill
Keeping Faith
Old 10-18-2019, 03:15 PM   #324
1966 22' Safari
Fredericksburg , Texas
Bill, the Aircraft Stripper I bought from the auto shop was within the last several months. If the EPA forced the manufacturer to lessen the toxicity of the original, I would hate to be around the original. What I purchased was vaporous and powerful. But it works well and in a short period of time. I would purchase the small cans because any left in the can with air would slowly rust the can. Make sure you rinse well if you use it. Good luck
Also, Citristrip works but not as quickly. But much safer.
Bubba L is online now   Reply With Quote
Old 10-18-2019, 03:23 PM   #325
wcronin4's Avatar
1978 31' Sovereign
Thanks Bubba. It’s always better if you find something someone else has used.
Bill
Keeping Faith
Old 10-19-2019, 09:02 AM   #326
wcronin4's Avatar
1978 31' Sovereign
Dang Vistas
After I finished sealing three vista windows, I drown them in water and they didn’t leak. I sprayed them from every angle. No leaks.
This morning tropical storm Nester paid us a visit, and all three vistas leaked badly. Frustrating.
Now faced with decision on how to proceed. Options:
1. Figure out a way to strip out all the sealant and remaining gasket, free the single pane glass up in a double pane frame and figure out a way to reset everything. At first thought I don’t think this is possible, but I haven’t tried either.
2. Remove all three windows, break the frames apart (which I have tried to do already without success several months ago) and start from scratch. I am concerned that the rivet holes are becoming shop worn. They have already been enlarged to 5/32”.
3. Remove them and cover the holes with a patch.
If anyone has thoughts, advice, suggestions or a really cold beer, I’m ready!
Old 10-19-2019, 08:41 PM   #327
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I agree, dang vistas! I blame Oldsmobile for them. Such windows were popular in the 70s. I read nothing but trouble with them in vintage trailers here on these Forums.
I'm helping a friend with his 76 Sovereign this winter. His has vista windows, four of the dang things. The film his failed, they look bad, and they likely leak.
Invent a good way to rebuild these windows for me. I'll use it shamelessly.
David
WBCCI #8607
VAC Region 11
Old 10-21-2019, 09:47 AM   #328
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We went from double pane to single pane on the vista views, and filled the gap on the inside with vulkem, smoothed down pretty. (It was a LOT of vulkem). BUT, they haven't leaked since we did that. I'll see if hubby will expand on that here.
I know of many threads and people I've talked to that remove and patch the Vista views as too much trouble to make leak proof. But, we like the Vistas because in sunny cold weather, we can open their shades and get solar heat into the trailer. On cloudy days, opening the shades brightens up the interior of the trailer. We're not willing to get rid of them.
But, it's entirely up to you if you keep them or not. I don't judge.
Kay
Old 10-21-2019, 03:26 PM   #329
wcronin4's Avatar
1978 31' Sovereign
International badge
Hey everyone
I know this was buried in last major post I made but I really would like to get some input.
The badges have been hand painted and the original white paint is faded. They are a mess.
Can these be sand blasted? Anyone have any experience restoring them?
Old 10-21-2019, 06:41 PM   #330
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
I would lean towards trying paint stripper first. Even blasting with glass beads will tend to wear away the sharp edges of your lettering and border. Test a small area, or even the back side to make sure the stripper doesn't etch the metal itself.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 10-22-2019, 09:17 AM   #331
Minno's Avatar
1972 31' Sovereign
We stripped off what was left of the paint on ours when we stripped off the clear coat (aircraft stripper will do that). I hand painted them with Rustoleum paints, and cleaned off the letters with Q tips and paint thinner while still wet. Detailed work, but they came out looking very nice. I touched them up this past summer for the first time in 6 years.
It's one of those "insanity" things with me. I like to make "insanity quilts" too according to my quilting friends: lots of small pieces.
Kay
Old 10-24-2019, 07:51 PM   #332
wcronin4's Avatar
1978 31' Sovereign
Kay
My wife is a quilter. She explained what an insanity quilt was. Lot of similarities in redoing an AS. Lots of detail work.
Bill
Old 10-24-2019, 07:53 PM   #333
wcronin4's Avatar
1978 31' Sovereign
Kay and 57vintage
I switched to another paint stripper and the badges are paint-free. Post a pick tomorrow.
Bill
Old 10-25-2019, 08:06 AM   #334
wcronin4's Avatar
1978 31' Sovereign
Here is a pic of the badge with paint removed. Now, the question is how to paint it?
Bill
Old 10-25-2019, 11:48 AM   #335
wcronin4's Avatar
1978 31' Sovereign
David, you used induction senders for the new tanks you installed on your last project. How many wires did you have to run for each sender?
Kay, I’m going to repainted badges as you suggested. But they kind a look cool with no finish.
I’m trying to get the outside all sealed up before I start on the interior. So anything that has to be removed to be painted, I want to do it now so I can check for leaks before the interior insulation is installed.
Bill
Old 10-26-2019, 06:38 AM   #336
steinVT's Avatar
1956 22' Safari
1962 28' Ambassador
Williston , Vermont
One thing I did which may have been overkill, was to get a can of Eastwood's Seam Sealer and paint over every seam or rivet I could see from the inside. Prior to that I had removed the old dried out black factory sealer with a wire brush mounted on an angle grinder. Nasty dirty job.
Like I said, probably overkill, but I figured I never wanted to see the inside of those walls again. - Mark
Our Restoration Blogs: 1956 Safari and 1962 Ambassador
steinVT is offline   Reply With Quote
Old 10-26-2019, 07:42 PM   #337
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Bill in sunny Florida from snowy Colorado: I have used the Garnett SeeLevel systems for my water tank levels. The stick on "circuits" have two wires coming out of them. Then it takes a two conductor 18ga wire to "daisy chain", or tie in all three circuits together and run this single 2 conductor wire to the instrument. Mulitplex is a wonderful thing. The instrument also requires a 12v power wire and a good ground.
Easy enough that even I can do it.
David
Name:	1802 SeeLevel Fresh Circuit (Small).JPG
WBCCI #8607
VAC Region 11
Old 10-28-2019, 09:32 AM   #338
Minno's Avatar
1972 31' Sovereign
Yes, that badge does look cool with no paint. Ours weren't quite so pretty before I painted.
For those without a quilter in the family: an "insanity quilt" is one you must be insane to make because it is either very complicated and/or full of so many tiny pieces so you must be "insane" to make it. My apparent specialty! One of my current projects is making a Hawaiian hand appliqued quilt for my granddaughters graduation. We just passed high school, so now it's for college grad. Maybe.
Kay
Old 10-28-2019, 08:29 PM   #339
wcronin4's Avatar
1978 31' Sovereign
David
So each of the tank senders are wired in series?
Bill
Old 10-28-2019, 08:37 PM   #340
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Correct. David
WBCCI #8607
VAC Region 11
shell off, sovereign
Frame Rust 1978 Sovereign 31" TGRIMM Repairing/Replacing Floor &/or Frame 4 12-04-2018 08:17 PM
Frame off vrs. Frame on RedRdgRnr Repairing/Replacing Floor &/or Frame 19 05-15-2018 08:31 PM
1978 31' 1978 Airstream Sovereign Land Yacht - South Florida JoshuaSteven Airstream Classifieds 0 08-12-2015 08:58 PM
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 11:46 PM
Frame off or not off... till Repairing/Replacing Floor &/or Frame 16 11-19-2003 06:20 AM
