Old 08-20-2011, 01:23 PM   #1
Darrengj's Avatar
1968 22' Safari
Fort Myers , Florida
Frame through side by wheel well
We have frame sticking through in front and in back of the curb side wheel well. Is this just where the rivets have come apart on bottom and let the frame poke through, or could it be a sign of something worse? Thanks.
ID:	138222   Click image for larger version
1968 Safari 22'
https://jenkinsonairstream.wordpress.com
Darrengj is offline   Reply With Quote
Old 08-20-2011, 01:32 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The vibration going down the road has caused the out riggers to wear through the aluminum. It is most often caused by axles that have no bounce in them and/or out of balance tires/wheels/brakes.
Richard
Old 08-20-2011, 01:33 PM   #3
SteSpot's Avatar
1982 24' Airstream 240
Ventura , California
Outriggers sticking out
It looks to me like your outriggers (they are attached to your frame) are cutting through the sides of your trailer.....we had that on our 69 Overlander that was broadsided.
We also had a rotten floor, rear end separation and needed new axles. I am not sure which of these conditions caused our outriggers to slice through the sides but it needs attention. Sorry about that, I am sure someone more knowledgeable than I will chime in with more information. I am sure it is fixable. Paula
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 08-21-2011, 08:42 PM   #4
Darrengj's Avatar
1968 22' Safari
I do have rear end sag on the same side and the axle will most likely need to be replaced. So probably a combination of those two problems for me as well. Thanks for the help.
1968 Safari 22'
Old 08-21-2011, 09:44 PM   #5
Outriggers in later year trailers have a flat surface on the outer edge, most of the time.
When they cut thru the underbelly wrap, that is a clear sign of a harsch ride, vibration and/or bad rubber rods in the axle.
Harsch rides come from over hitching, lack of proper running gear balance and/or bad rubber rods in the axle, as well as a super heavy duty tow vehicle.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-21-2011, 10:04 PM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
The same was/is happening to our Trade Wind. 2 years ago when I was having the entire street side lower panel replaced I saw where the outrigger was slicing through the skin and where a couple of others were begining. Floor was solid and axle is newish. However it appeared that some of the outriggers were longer or poorly exposed in the manufacture. Before the Airstream repair shop installed the new panel (4' x 14') they fashioned a 'shoulder' of sorts to eliminate the sharp edge from wearing through the skin. I have one beginning to wear through on the curb side and plan to pull the bottom of that panel enough to slip and anchor similar 'shoulders there.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Dump side question Tradermack Waste Systems, Tanks & Totes 7 05-19-2011 04:09 AM
'69 Overlander frame repair colin57 Repairing/Replacing Floor &/or Frame 6 04-25-2011 10:45 AM
frame reinforcement - rear end separation silversafari Repairing/Replacing Floor &/or Frame 1 03-17-2011 10:16 AM
1965 Caravel Frame funhouse 1956 - 1965 Caravel 0 03-01-2011 09:12 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
