RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-23-2011, 08:40 AM   #1
aluminomad's Avatar
1968 22' Safari
Salem , Massachusetts
22' needs stabilizing
could not find answer in forums when searching key words etc... on a 68 22' Safari... what do we need as far as stabilizer jacks go & where is the safe/correct place to place them? I'm hoping we can get such at an RV dealer & not specifically Airstream... although we plan to visit one by months end... just hoping to stabilize this weekend
Thanks ~T
aluminomad is offline   Reply With Quote
Old 07-23-2011, 08:57 AM   #2
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
You can place 2 in the front under the A frame close to where each A frame member meets the main frame rail. Then place one aft of each tire (you will see a small 3" patch on the belly pan) again on the frame rails. For the rear two you can also place them further back where the main frame is welded to the bumper. This latter place is for stabilizing only, Do Not Lift Or Level the trailer from this point.
Kevin
kevinb is offline   Reply With Quote
Old 07-23-2011, 09:00 AM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I have a 68 28' Ambassador. I put 2 in the rear where the frame comes out from under the belly pan. right by the bumper. and 2 up front on the frame right at the start hitch area. I just have jack stand type. But if you are going to mount them you would want them mounted to the frame for sure.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-23-2011, 09:05 AM   #4
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Yes you can get them from any RV dealer, a set of aluminum stacker jacks (4) run about $ 40.00
Old 07-23-2011, 09:10 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
On our 63 we used a model like this bolted to a one foot square of 3/4 plywood.Rv Stabilizer Jack 5000 lb
These are also popular http://www.rvpartscountry.com/StackJacks4Pack
Ive always thought that over planning was just a firewall against not being sure of what you really want to do.
RLC
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 07-23-2011, 09:30 AM   #6
aluminomad's Avatar
1968 22' Safari
Kevin
so in essence I could get by w/just 4? & TY for all the info! we've had to do thing very slowly due to well everything but stabilizing is up there w/the roof vents... but they just need weather stripping (they only leak if it rains wicked or it's wicked windy when it rains)
Old 07-23-2011, 12:00 PM   #7
Thanks ~T
Airstream uses a different size stabilizing jack. It has a 13 inch turning bolt instead of the 6 inch.
That then allows you to see the turning bolt, so that you don't have to get on your hands and knees.
The stabilizing jacks have 3 mounting holes. Two go directly to the frame. The other one is used to attach it to the frame "crossmember".
The jacks in your case, should be mounted just below the very "first" and "last" main bow. That will give you 12 foot spacing between the jacks.
Regular RV dealers would not likely have the Airstream type BAL jacks.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-23-2011, 12:30 PM   #8
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Andy above is correct. I installed 4 of the BAL jacks on my 65 Safari in the locations Andy mentioned. Only needed a drill and socked and only took me 45 minutes. They really work great. I use an elect. drill/ socket to operate the jacks.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 07-23-2011, 12:41 PM   #9
aluminomad's Avatar
1968 22' Safari
we went to Lee Family RV, Windham ME & got a set of 4 for about $40... hubby put them where suggested (@ A & behind tires in patch) & so far so good... wiggles pretty much gone
Old 07-23-2011, 03:40 PM   #10
Don't know what you bought, but I don't think it was the BAL jacks that Airstream uses.
Airstreams price for a set of 4 BAL jacks is $322.00.
How about a photo or 2?
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-23-2011, 05:01 PM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Sounds like a set of these Aluminum Stack Jacks - Product - Camping World. They're what I always used on my Trade Wind. I was envious of the BAL jacks but never upgraded.
Vaughan
Old 07-23-2011, 05:09 PM   #12
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
So, are you guys using these jacks in addition to the four stabilizers mounted to the trailer?
A Blog from the Devil's Triangle
https://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 07-23-2011, 05:52 PM   #13
1983 34' Excella
1967 24' Tradewind
Images: 32
In my Trade Wind's case, none mounted to the trailer. That's why I was envious of the trailers that had the BAL jacks mounted. All these responses were about '60s vintage trailers.
My '83 Excella has the BAL jacks mounted on the trailer, so I wouldn't use the stacking stabilizers. Even if I could find all of them.
Actually, I don't mind the movement. Sometimes I don't put the stabilizers down at all.
Vaughan
Old 07-23-2011, 06:01 PM   #14
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Vaughn!
I am with you, particularly on my tandem axle coach as in many circumstances the tandem is very stable on its own -- my single axle Minuet on the other hand, is a bit too nautical without having its stabilizers deployed.
Kevin
Kevin D. Allen
AIR #827
Old 07-23-2011, 06:49 PM   #15
one of those
Gringo's Avatar
Ah, now I see. The earlier trailers didn't have factory stabilizers attached. Now I got it.
I still wish mine was steadier. I wake up at the least movement. or noise. or light. or random idea.
Old 07-23-2011, 07:11 PM   #16
1983 34' Excella
1967 24' Tradewind
Images: 32
Well, you could try some. I can't see how four more stabilization points would not help, at least some. They're not expensive.
I've used them for other things too. Just don't try to hold up a car with them.
Also, when you're using them, be sure you don't get the propane line between the jack and the A frame. Even though you're just trying to stabilize the trailer, you could mash the line a little with movement. Then next time, a little more. You get the idea.
Vaughan
Old 07-24-2011, 07:59 AM   #17
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Another thing I like to do is place a small piece of wood (1x2) between the stabilizer and coach to increase the surface area.
Kevin
Old 07-24-2011, 08:05 PM   #18
aluminomad's Avatar
1968 22' Safari
yup
we can't afford anything fancy @ this point... but we needed to stabilizer her since she didn't have any of her own
Old 07-24-2011, 08:38 PM   #19
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Whatever works for ya. You should be able to get your money back by selling them on Ebay and buying the correct jacks at a later time when you can affort it. Save up yur money.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 08-02-2011, 08:16 AM   #20
aluminomad's Avatar
1968 22' Safari
??? how can they be the correct jacks if the 68's didn't have them to begin w/? anyhoo... this is our home... better than a cardboard box & now stable... THANKS for EVERYONES help... I'm sure I'll have more posts w/our slow progression~ <3 T
Adapting 5th Wheel Stabilizer for A-frame tongue stabilizing? IndyAnne Jacks, Stabilizers, Lifting and Leveling 3 05-30-2011 01:58 AM
Jack point on 20 foot-Caravelle/Argosy ? glacierrunne Jacks, Stabilizers, Lifting and Leveling 1 03-16-2011 11:53 AM
