RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-25-2020, 01:34 PM   #1
2018 25' International
Lewisville , Texas
Replacing Broken Window Glass
One of the 28 x 30 inch windows in my 2018 25FB camper mysteriously exploded (after it hit our gate while pulling out on day one of a 5 day trip)
We see it as just another chance to learn from our many mistakes. We actually just took it in stride and worked the problem. I ran off to Home Depot and bought a 30" by 36" piece of thin plexiglass. Using some speed tape (aluminum tape) I first stuck a foot long segment to the skin behind the rock guard to see if it would be impossible to remove. After about 30 minutes it peeled right off, so I felt I could safely go to town on our window.
We drove about 800 miles round trip through all sorts of conditions and it held up great!
After getting home I ordered the new window and plan to put that in myself. Doesn't look too difficult at all. Window appears to come with all hardware already installed.
Name:	Broken Window.jpg
Matt & Roxanne
2018 FB Twin INTL Serenity (The Flying Squirrel)
2019 F250 DIESEL (Ferdinand)
@tflyingsquirrel
mattRox is offline   Reply With Quote
Old 11-25-2020, 03:14 PM   #2
1966 22' Safari
Fredericksburg , Texas
It’s not an uh oh if you can repair it. Could’ve been a lot worse. Just add one more piece of experience to your knowledge base. Happy travels and stay safe.
Bubba L is offline   Reply With Quote
Old 11-25-2020, 05:51 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Very easy to replace. I had a roadside window taken out on a chipseal highway this summer. Covered mine with poly until the new window arrived. Took about 15 minutes to install the new window. All of the hardware is on the window. You will need a stepladder or a 3 step stool to get the window onto the top track, as you need to have the window about 120 degrees to the opening.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 11-27-2020, 02:23 PM   #4
LVCOTLV
2013 27' FB International
Ventura , California
Where to buy?
Hi. This happened to me just now, the shards are still in the grass as I type. With mine, the window was stuck to the seal and a certain someone used brute strength from inside using the lift tabs and the lift tabs went up but the glass shattered. Love that certain someone...she’s a peach. (Lol)
Anyhow, I’m off to Lowe’s for plexi. But where did you order the glass. Quick search online is complicated. They all want to sell the whole assembly from sash and gaskets.
Will hope to get glass only or at most hardware on glass included.
Roscoe1996 is offline   Reply With Quote
Old 11-27-2020, 02:28 PM   #5
LVCOTLV
EDIT: this is on a 2013 Int. Serenity 27fb. It is the front bedroom curbside window (opposite egress window).
Old 11-27-2020, 05:14 PM   #6
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Go to your nearest Airstream dealer. These windows are Airstream specific.
ACI #7394
1976 22' Argosy
Hensley Hitch
Old 11-28-2020, 07:15 AM   #7
Lewisville , Texas
My local dealer wouldn’t just order the part. They wanted me to drive it in and leave it. Didn’t have any windows in stock, either.
https://highskyrvparts.com/
The frameless was half the cost.
Frameless Side Window Glass Curved 30-1/2" x 28-3/4" - 195510-93
- Glass Shipping Box: Glass Shipping Box 1 $353.22
Sub-Total: $353.22
UPS Ground: $78.40
Total: $431.62
Matt & Roxanne
@tflyingsquirrel
Old 11-29-2020, 03:47 AM   #8
LVCOTLV
Thanks CBWELL for the thread and the advice. I ended up ordering the exact part from HighSky RV that mattRox suggested. I did the plexiglass temp, except I cut it the size and shape of the window , drilled holes for the lock brackets on the bottom, the lift levers n the side and the hinged stay bracket in top. While this temp fabrication works to keep the wind out, it rattles a bit when locked and I won’t trust it on the highway.. tape is probably better . Or a thicker plexi glass
Old 12-03-2020, 03:17 PM   #9
Lewisville , Texas
Two weeks in and still waiting for the part to arrive. The email said "Be patient, part may take 3 weeks". No tracking number. Oh well.
Matt & Roxanne
@tflyingsquirrel
Old 12-04-2020, 03:57 AM   #10
LVCOTLV
Waiting on glass
mattRox, I should be somewhere behind you in line for the glass. I will stop running to the door every time I hear the UPS truck emriubdvthebcirber. I hope it goes alright. I looked for an email, and nothing. I better give them a cal.
Old 12-04-2020, 07:43 AM   #11
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I ordered mine from CanAM in London Ontario. They normally have stock but were out and waiting for a shipment from Jackson Centre. The first window came broken because of bad packaging and probably poor handling. They shipped the second at no charge to me. I imagine this time of year the freight companies are way behind, and with the Covid problem things are even worse. My total wait was almost a month.
ACI #7394
1976 22' Argosy
Hensley Hitch
Old 12-04-2020, 08:07 AM   #12
Jim J
Jim J's Avatar
2014 30' Flying Cloud
Me Too
This happened to me on a road trip a few years back, I had left a bedroom window unlatched. A passing semi sucked it open and broke it. Of course it was raining. I discovered it at our next stop when I went in the trailer to use the bathroom. Sounded a bit noisier than usual.
I cleaned up the mess and stopped at a Home Depot about a mile away. I was going to put up a quarter inch thick piece of plywood that I would cut to fit the opening but decided to go with a piece of corrugated package material that I cut with a pocket knife, covered with a garbage bag, and sealed with duct tape to the area around the window. This was a much cheaper and quicker temporary fix than my original idea.
I put this on north of Dallas, Texas and it held up fine for the next several days until I finally made it by Jackson Center to get another window and install it. Duct tape came off leaving a little but of residue which was easy to clean up using some auto cleaner wax.
Now, I always check my window latches from the outside of the trailer as I do my final walk around before leaving for the road.
Jim J is offline   Reply With Quote
Old 12-04-2020, 08:18 AM   #13
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Is emriubdvthebcirber a new word that I am not familiar with or did the typewriter run wild on its own?
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 12-04-2020, 09:02 AM   #14
RivetED's Avatar
2004 25' Safari
2018 26' Flying Cloud
2019 25' Flying Cloud
North Central Texas , USA
This is a fairly common issue. I think the combination of the tempered glass window, a non-yielding gasket, and the flexing of the Airstream body adds to the possibly of failure. Of course if the window hits something or gets hit by road debris or stones then it's going to be an 'oh well' moment.
I'm going to have sun-shade film put on ours, another project on the to-do list, but I wonder if the film will at least keep the glass pieces intact enough to get it home. I've seen side windows on cars that have held up after being shattered, just thinking that could be another rationalization for adding the film. Anyone have experience with that?
I do keep the gaskets 'seasoned' with 303. Between the two of us it seems like sooner or later the lift levers might do the same thing as Roscoe1996 and others have had happen.
Back to emriubdvthebcirber I can usually decipher spell check or typos but you got me on this one!
-Ed
RivetED is offline   Reply With Quote
Old 12-10-2020, 03:53 PM   #15
Lewisville , Texas
To those of you waiting on parts, I contacted Sky High RV Parts today as it has been three weeks since the "shipping" date.
The customer service person said that Airstream is running one or two or three weeks behind the three week quoted time. I believe the word COVID was mentioned at least 7 times.
I asked if I would receive a tracking number and they said Airstream does NOT provide tracking numbers.
Hope this helps,
Matt & Roxanne
@tflyingsquirrel
Old 12-31-2020, 08:59 AM   #16
Lewisville , Texas
Six weeks today. Still no specific information about my window from Sky High.
Matt & Roxanne
@tflyingsquirrel
Old 01-11-2021, 02:56 PM   #17
Lewisville , Texas
The window arrived today. 7 and a half weeks after ordering. The Airstream factory was closed for almost two weeks during the holidays but the folks at the parts department in Jackson Center said that 6 to 8 weeks is about right.
Installation was simple, but now the window doesn't close completely unless someone pushes on it from the outside. I think it may be that the glass lost a bit of it's curve during shipping and will soon conform to the proper bend, but we'll see. It's a tam operation now.
Matt & Roxanne
@tflyingsquirrel
Old 01-11-2021, 04:48 PM   #18
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Check to make sure that you have the top hinge in the track correctly! You don't want to put tension on the window or you will be replacing again. Glass does not change its curve once it is made. There might be some foreigh particles in the track, so clean them out and reinstall.
ACI #7394
1976 22' Argosy
Hensley Hitch
Old 01-12-2021, 12:27 AM   #19
LVCOTLV
Thanks MattRox. No notice yet that it has shipped, but should be soon. Will update with pics when it arrives. And if you end up sending it back because the curve no’s not right, I may have the same problem. Will let you know.
Old 01-12-2021, 04:38 PM   #20
Lewisville , Texas
Thanks for the suggestion. I was mistaken. It’s not the curve of the window, I think it’s an arm binding a little bit. The window closes completely on one side and is less than a half an inch off on the other. I will take it off again and inspect but it looks good.
Also, there was no notice of shipping until the doorbell rang.
Matt & Roxanne
@tflyingsquirrel
Broken Window AND Broken Plexiglass Rockguard pianolaw Windows & Screens 0 02-16-2020 02:40 PM
Help removing broken window glass and sealer Jenniflow Windows, Doors, Locks & Vents 0 04-12-2019 12:52 PM
Replacing window glass StreamRoller Windows & Screens 7 03-13-2017 08:01 PM
Replacing window glass in '50s Airstream zgears Windows, Doors, Locks & Vents 3 03-03-2012 08:36 PM
replacing windows - glass, lexan, tempered glass? BrianY Windows & Screens 4 07-01-2010 01:08 PM
