Recommendation for replacement water pressure regulator
Hello,
I have a 1971 Land Yacht Overlander and I can't get water to run through the city connection system. After reading the threads and through process of elimination I believe the issue is a frozen and closed water pressure regulator. I believe I've checked all the valves which were open in addition to the facet and water heater drain -> no water.
Question 1: has anyone else experienced this problem and if so, what was the cause and remedy?
Question 2: where is the best place to purchase a durable water pressure regulator valve?
Question 3: what problems should I expect when replacing the existing regulator and what parts should I consider purchasing to fix whatever else may not work/break when I replace the regulator?
Thank you,
Travis
