02-13-2022, 11:24 AM
1992 36' Land Yacht
Grayson
, Georgia
Great rear brake videos
Found these videos online and thought I'd share.
I'm planning to do a complete rear brake rebuild this spring and getting things ready for the job. Found this video and it answered many questions I had on servicing the rear brakes on a P32 chassis.
The goal is to replace the calipers, rotors, pads, rear wheel seal, lug bolts and center rubber brake line. The left and right-side rubber lines were replaced a few years back.
Currently have the rotors, calipers, brake line and pads at the house. Still need to pick up the rear seal but need to identify exactly which rear end I have in order to order it. Seems like there were several different seals used depending on which rear diff I have. I could measure the seal but then I would have to remove the rotor first and wait for the parts to arrive or hope that a local parts store has it in stock.
If anyone can add any comments to what the video is saying or any other things I should be looking for, please feel free to share. I only want to do this job once.
02-14-2022, 05:38 AM
1984 27' Airstream 270
West Chester
, Ohio
I don’t think you are missing much here. Believe the rear axle is Dana 70 HD. The seal may be a remove and measure to replace. Can’t remember which year they went to Dana 80.
Also, may want the socket used to remove those lock nuts. Not that removal is so bad, but there is a specific process for torque while turning the hub to load the bearings. I wouldn’t want to guess
02-14-2022, 06:08 AM
1992 36' Land Yacht
Grayson
, Georgia
I'll look more into which rear end I have. Unfortunately, a few years ago, I had a truck repair shop fix a faulty speedometer issue. Turned out to be a faulty drive module, but they needed to count the ring and pinion gears to verify which one to replace it with. In the process they removed the metal tag on the rear cover bolt and never replaced it. Makes it harder to identify which rear end I have. I guess I'll keep looking.
I already have the socket used to remove and replace that lock nut. Picked that up at the same time I picked up the rotors, calipers and pads.
02-14-2022, 07:05 PM
1991 35' Airstream 350
Columbia
, Tennessee
GM went to the Dana 80 in 91 when they put the 4L80E transmission.
Brakes are just about the same as the Dana 70HD on the early 80's. I'm thinking the duel piston calipers did not show up until the Workhorse chassis!?
I did a job on a 2001 3500HD chevy truck with the Dana 80 and bigger rotors, but still had the single piston.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
02-15-2022, 11:54 AM
1992 36' Land Yacht
Grayson
, Georgia
It is a 1992 model, and it does have the 4L80E transmission.
I think that I've been able to confirm that it is indeed a Dana 80. Looking over the differential today, I found the number 80 cast into the housing. The size of the axle tubes appears to be larger in diameter than a Dana 70. Probably around 4 inches in diameter. Didn't have a caliper to measure it exactly. Right now, I'll assume it is a Dana 80 and pick up parts as needed.
02-15-2022, 12:04 PM
1992 36' Land Yacht
Grayson
, Georgia
Can someone confirm that a Dana 80 is a Spicer 80? I have two seals from National Oil Seals PN 6358 and they're for a Spicer 80 according to Rock Auto.
02-15-2022, 09:37 PM
Columbia
, Tennessee
Here is the seal I used for the rear hub: National Seal 40235.
On bearings and seals, if in doubt, I like to have them in hand and order from a great parts store here that sells Timken bearings and seals as well as National.
Return to Rock auto can sometimes get risky if you have ordered wrong parts! Have a couple of times, with some seals and bearings, and was just better to not return em! Return shipping wiped out the savings!
AIR Member 12654
1991 350LE "Zephyr"
02-15-2022, 09:39 PM
Columbia
, Tennessee
Sorry about the upside down phots. If you rotate them with an edit, this site will always flip them back to the original! O well, cant have everything!
AIR Member 12654
1991 350LE "Zephyr"
02-16-2022, 05:10 AM
Richmond
, Kentucky
Sometimes when this happens I will take the picture and reduce the size by 1 pixel and then rotate it. That seems to work for me.
1975 24' Argosy Motor Home
02-16-2022, 06:49 AM
Columbia
, Tennessee
Thanks Brad, I will give it a try.
AIR Member 12654
1991 350LE "Zephyr"
02-16-2022, 07:01 AM
1992 36' Land Yacht
Grayson
, Georgia
On bearings and seals, if in doubt, I like to have them in hand and order from a great parts store here that sel40235ls Timken bearings and seals as well as National.
Attachment 412034
Attachment 412035
Attachment 412036
Not sure we have the same rear end but everything I've found seems to indicate that the National part for the Spicer 80 is 6358. Can't find the 40235 part number anywhere. Just need confirmation that Dana and Spicer are the same for a chevy.
02-16-2022, 07:19 AM
Columbia
, Tennessee
Julius, I would make sure that you have seal in had, just incase!
We should have the same rear if it looks like the photo of my hub. There was not much changes of the 80 in the early years used on GM.
Eaton I believe is just a supplier of components that would/could be used in the Dana 80 and other driveline products.
When I did the Dana 70HD on the 310, the brakes and hubs were, as far as I can tell, the same. In fact I ordered the same brake parts for both units!
The retainer nuts just a little different, that the 70HD did not have the slots go clear across the nut face, so the nut driver would not work until I slotted the nuts completely!
AIR Member 12654
1991 350LE "Zephyr"
02-16-2022, 04:16 PM
1992 36' Land Yacht
Grayson
, Georgia
I still can't find a seal with that specific part number. Do you have a source?
02-16-2022, 06:19 PM
Columbia
, Tennessee
I will check with my supplier tomorrow morning and get back with you.
Thought I had a photo of the box, but of course not!
AIR Member 12654
1991 350LE "Zephyr"
02-17-2022, 06:25 AM
1991 25' Airstream 250
Oxford
, Oxfordshire
Axle intell.
02-17-2022, 07:09 AM
1992 36' Land Yacht
Grayson
, Georgia
I think I know why I couldn't find the part number you posted. It's not 40235, it's 40285. That part does cross over to a Spicer/Dana 80 1992 model. I'll pick one of those up as well.
Edit:
For what it's worth, National P/N 6358 crosses over as an alternate part for 40285. So, I guess, we were both right. Oddly, the 40285 part is not listed for use in a 1992 P30. Most parts stores show its usage for a 98+ GM P30 while the 6358 is used before then. Not sure why since both have virtually identical inner and outer dimensions.
02-17-2022, 07:33 AM
1992 36' Land Yacht
Grayson
, Georgia
Originally Posted by Boom Sounds
Axle intell.
This is exactly what I was looking for. It does show that the Spiicer/Dana part number is 40285. It also states that there is no gasket seal between the axle cover. It states to use silicone sealer.
02-17-2022, 07:36 AM
Columbia
, Tennessee
Good to hear Julius, will save the information. Minor changes in seal technology changes, and so, will change the number even if physical the same sizes!
Sent from my SM-G950U1 using Airstream Forums mobile app
AIR Member 12654
1991 350LE "Zephyr"
02-17-2022, 07:44 AM
1992 36' Land Yacht
Grayson
, Georgia
Good to hear Julius, will save the information. Minor changes in seal technology changes, and so, will the number even if physical the same sizes!
That may very well be the difference. Most locations show the seal material on the 40285 as being simply Rubber while the National 6358 show as Nitrile Rubber (NBR). Since I already have the 6358 seals in hand I'll probably go with them. I don't see any reason to pick up the 40285 seals right now.
