Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 1964 Bambi II
Old 03-26-2014, 06:46 AM   #1
1955 22' Safari
Laredo , Texas
Removing fridge
Original Dometic fridge in poor condition so it needs to come out. Will probably go with a taller one (propane or electric, not sure yet) so Magic Chef cooktop also removed. I have removed gas line, two screws from bottom of front frame and two bolts from right rear of fridge and it will now rock in place but is unwilling to come out. Something seems to restraining it at lower right corner of front but I do not see any other fasteners - advice?
55AS is offline   Reply With Quote
Old 03-26-2014, 07:13 AM   #2
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I'm sure it depends on what model of refrigerator you have, but mine had four bolts in the bottom, one in each corner. It also had a strip of aluminum sheet metal tying the top to the wall that was hidden behind wood paneling.
Thalweg is offline   Reply With Quote
Old 03-26-2014, 11:36 AM   #3
1955 22' Safari
Laredo , Texas
Should have said lower left corner.
Removing Old Fridge Fletch8918 Refrigerators 2 11-09-2010 05:51 PM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
Removing the fridge... deepsea Refrigerators 2 04-05-2010 05:44 AM
removing fridge and oven mark silberl Refrigerators 2 11-15-2006 12:47 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
