Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 06-16-2019, 02:02 PM   #1
Johnson City , Arkansas
Refrigerator condensation
We have a 2017 25’ Rear Queen Flying Cloud. Frig takes a while to cool down, but my real question is that we get a lot of water (assuming condensation) in the bottom of frig. Does anyone else have this problem? Does anyone have a solution or is this something we have to live with?
Willk is offline   Reply With Quote
Old 06-16-2019, 04:49 PM   #2
Flht2k's Avatar
sacramento , California
Yes. Look at tray, you will notice when you pull it out that it has a pipe that goes into the hole. I installed an oring on the tube, get a thick one. That is a little smaller than the hole. Push in. Presto.
Flht2k is offline   Reply With Quote
Old 06-16-2019, 04:53 PM   #3
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
use a small circulation fan
it is a must if you are in a high humidity area
these fans make our fridge a more consistent temp and reduces frost build up
cheap and easy to make
Name:	fan in fridge.jpg
ID:	343559   Click image for larger version
Name:	fans in fridge-1.jpg
waninae39 is offline   Reply With Quote
Old 06-16-2019, 05:04 PM   #4
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Yep fans are a must.
ID:	343561   Click image for larger version
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
GMFL is offline   Reply With Quote
Old 06-16-2019, 06:27 PM   #5
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
Originally Posted by Willk View Post
...that we get a lot of water (assuming condensation) in the bottom of frig. Does anyone else have this problem? Does anyone have a solution or is this something we have to live with?
If your AS isn’t level condensation may not drain properly. Also the tray ‘spout’ could be too short. We solved this issue by attaching a short piece of tubing and directing it down the outlet hole.
az-streamer is offline   Reply With Quote
Old 06-16-2019, 06:43 PM   #6
Thanks!
Old 06-16-2019, 06:44 PM   #7
Thanks!
Old 06-16-2019, 06:46 PM   #8
Attachment 343565
Attachment 343566
Attachment 343567
Attachment 343568
Thanks! Sounds like this might be a good solution.
Old 11-02-2019, 07:53 PM   #9
2017 25' Flying Cloud
T , Ontario
We had the same issue. Just added a short length of clear vinyl tubing to the snout on the condensate drain tray to ensure the water goes all the way out to the tube in the wall to the outside. Does anyone have any suggestions what to do with the remaining 24’9” of tubing? Actually, I split three or four feet to make gaskets for the bottoms of the propane tanks to prevent metal on metal contact, but I still have quite a bit left .... handy stuff, annoying to schlep around. Wait, and to pad the picture wire they used to stop the outside hatch door from opening too far - it was cutting into the rubber gasket.
drobert33 is offline   Reply With Quote
Old 11-03-2019, 07:50 AM   #10
2020 23' Globetrotter
Savoy , Texas
GMFL & waninae39, what did you splice the wiring for the fans into.
SpinWhite is offline   Reply With Quote
Where does refrigerator condensation drain go? m.hony Refrigerators 23 01-17-2017 01:38 PM
Where does refrigerator condensation drain go? HowieE Plumbing - Systems & Fixtures 19 09-08-2016 09:34 AM
Window condensation Seon Windows & Screens 5 03-16-2003 10:19 PM
bed condensation kooblekidz Airstream Motorhome Forums 7 01-16-2003 08:52 AM
Window condensation????? Anna Windows & Screens 1 10-28-2002 10:51 PM
