Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1954 - 1959 Overlander
Old 01-18-2006, 03:47 PM   #121
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by ankornuta
So what is this weird plate thing in the front of the trailer holding the body on? It sticks up about 2" higher than the u-channel everywhere else?
Ankornuta,
Talk to me, is it a steel plate or aluminum skin material. I have an L shaped piece of skin at the front about 4" on each leg.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 01-18-2006, 08:14 PM   #122
ankornuta's Avatar
Lowell , Massachusetts
Images: 22
Bill, I think it's aluminum. But the damndest thing is that I have a "battery holder" type steel contraption welded onto the A-frame part of the hitch which is preventing me from drilling those rivets out of it.
I would like to grind the battery holder deal off and rebuild it anyhow (although it is original), but I don't really want to grind it right NOW, while there's still all that wood and junk (like the body) to catch on fire while attached to the frame...
So what was the purpose of this plate?
ankornuta is offline   Reply With Quote
Old 01-18-2006, 08:57 PM   #123
Over59's Avatar
Putnam , Connecticut
Images: 37
There is a steel plate in the front which attaches the frame to the shell. Look to drilling the rivets from the inside. I didn't have anything in the way from drilling from the outside. If you are careful you may be able to grind off the rivets from the inside and punch them out. You must put this or a replacement back on.
Over59 is offline   Reply With Quote
Old 01-18-2006, 09:45 PM   #124
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Does it look like this?
Akornuta,
Does your aluminum piece look like the one in this picture? I think that that is what was used to help secure the front to the floor in addition to the channel before Airstream started using a steel plate welded to the frame cross member and riveted to the front shell. RJ Dial's 1957 Flying Cloud has the same thing.
Bill
Old 01-18-2006, 09:46 PM   #125
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Over59,
I do not have this steel plate on my 1954 Liner.
Bill
Old 01-23-2006, 08:41 PM   #126
ankornuta's Avatar
Images: 22
It's steel on my '58, afterall. And I had to drill it out from the backside (inside the trailer), but it wasn't too bad.
Old 01-23-2006, 08:57 PM   #127
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Akornuta,
Do you have seven or thirteen panels on the end?
Bill
Old 01-23-2006, 09:20 PM   #128
Images: 59
The front plate should look like this:
Name:	Front Crossmember.jpg
Old 01-23-2006, 09:29 PM   #129
ankornuta's Avatar
Images: 22
Originally Posted by wkerfoot
Akornuta,
Bill
Why seven of course
Old 01-23-2006, 09:29 PM   #130
ankornuta's Avatar
Images: 22
That's the stuff...
Old 01-23-2006, 09:38 PM   #131
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Why seven of course
Ankornuta,
Thanks, I am trying to tie down the appearance of the steel plate, it appears to have arrived with the seven panel end caps. This is RJ Dial's assumption as he does not have it on his 1957 Flying Cloud and I do not have it on my 1954 Double Door Liner.
Bill
Old 01-23-2006, 09:45 PM   #132
ankornuta's Avatar
Images: 22
Gotcha. I guess this plate was probably one of the first places that the body was attached to when putting the shell down on the floor.
One of the things I've been wondering about while taking the body off was if they built the body in place on the frame, or built it separately and then lowered it down onto the floor...
Old 01-27-2006, 03:58 PM   #133
Over59's Avatar
Images: 37
Progress
New deadline. Cherry Blossom in April
ID:	17960   Click image for larger version
Old 01-27-2006, 07:01 PM   #134
Over59's Avatar
Images: 37
What we have here is the interior skin being put on and the tub being reinforced on the bottom and edges.
Old 02-07-2006, 04:01 PM   #135
ankornuta's Avatar
Images: 22
Paul, is that new aluminum for the interior? It looks awfully shiny....
Old 02-13-2006, 02:03 PM   #136
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
Ankornuta,
Bill
The plate was on my 1954 Cruiser. It is identical to Markdoane's.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 02-15-2006, 05:40 AM   #137
Over59's Avatar
Images: 37
Interior walls are polished aluminum. We will see how that works. Can always paint them if it doesn't work out.
Old 02-16-2006, 09:50 PM   #138
ankornuta's Avatar
Images: 22
Looks nice!
Old 04-06-2006, 10:16 AM   #139
Over59's Avatar
Images: 37
Not making it to the Cherry Blossum this year..... But... the panels for the beds are in, ordered the foam, ordered the stove, and ordered the fridge. Ready to cut the Corian for the Bathroom and trim the tub which is otherwise done. I think we will be functional for Salisbury Beach at the end of April.
Old 04-10-2006, 11:30 AM   #140
ankornuta's Avatar
Images: 22
Glad to hear that you're getting closer! I can't wait to be at that point with my project.
Lower door step TomW Steps 33 02-17-2022 03:17 AM
Step repair took 3 hours--Airstream paid Kistler Our Community 8 11-12-2004 08:09 AM
Need a step? jcanavera 2000 - 2004 Safari 8 01-26-2003 11:05 AM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
