Originally Posted by PKI
Sounds like the fresh water CHECK VALVE is leaking. A check valve is a device that allows water flow in one direction. They are notorious for leaking. Located in close proximity to your fresh water pump.
You might try turning off shore water, running water until pressure is released. Then run the fresh water pump to move some water out of the tank and flush out the valve a bit. Then turn the shore water back on and see what you get. It is a "likely no luck" kind of thing, but might reset the valve.
Replacement is a good thing if the problem persists.
Good luck. Pat
Edit: 2018 - make this a dealer problem at your earliest opportunity. Waranty is a good thing to use. Opportunity to ask lots of questions.
Pat--thanks for this. I did as you suggested and completely emptied the fresh water tank. Have turned shore water back on and so far, all is well. I have a service appt at the mothership later this week and will ask them about it too. In a somewhat related note, my pump seems really loud when it is running. I'm not sure what normal is, but am going to ask about that too.
Thanks again for the quick response. Fingers crossed the valve is ok for now.
Laurie
