03-04-2019, 07:11 PM
2018 30' Classic
Thousand Oaks
Shower Fan: new problem
Was working. Now it’s not. Checked fuses and nothing is flipped. Since this is a manual on/off and seemingly not connected to anything, is it possible it just has a little fuse on the motor I need to check?
Any thoughts on trouble shooting? Have an appointment at airstream mothership on the 19th, will have them look at it ultimately but would love to have a vent fan going for my hot and steamy showers.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
03-04-2019, 07:14 PM
ObviouslyKnot
KAILUA
, HI
Just thought twice. Can edit, but not delete.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
03-04-2019, 07:18 PM
2018 30' Classic
Thousand Oaks
Lol. You sparked my curiosity, didn’t see the original post.
BigSxyWhtGuy
03-04-2019, 07:31 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
No fuse on motor. Maybe a bad switch. The little red clicker switch may not be making contact. If you have a way checking the voltage pre and post switch would be my starting point. If you have 12 volts before and 12 volts after the switch the only thing left is a bad motor.
03-05-2019, 10:49 AM
Okstreamer
2007 25' Safari FB SE
Yukon
, Oklahoma
Probably the switch
Probably the switch, I had the same problem and I just got to the switch and sprayed some silicone lubricant into the switch and cleaned it out and the fan has been working fine ever since. Just be sure you disconnect the power first.
03-06-2019, 04:35 PM
2016 26' Flying Cloud
Wayland
, Massachusetts
We have a 2016 Flying Cloud 26RBQ. Our bathroom fan did the same malfunction thing. We ultimately replaced it as I tried everything and could not get it to work. We ultimately replaced the whole fan. It was not really expensive and I had tried everything.
03-06-2019, 06:02 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I’d also say it’s the switch. I had one go bad a few years back
2019 Ford Expedition Platinum
03-07-2019, 03:12 AM
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte
Any thoughts on troubleshooting? Have an appointment at airstream mothership on the 19th, will have them look at it ultimately but would love to have a vent fan going for my hot and steamy showers.
Had my bath fan go out on my 2012 EB. It was the motor, not the switch. Somewhat not unexpected as AS does not use a sealed motor and the constant exposure to steam is less than healthy for spinning electrical components.
Have you tried to start it spinning? Use a pen and just give it a flick. If it starts then it is the motor. Easy repair. Replacement motor available on Amazon.
2019 30' Classic RB pulled by 2018 Dodge RAM 3500 short bed
