Old 03-10-2019, 01:44 PM   #1
2018 30' Classic
Rock Hall , Maryland
Dometic A/C
I have a 2018 30ft classic. Does anyone know which a/c is the 13.5K btu and which one is the 15k btu? Model numbers?
Also, if I were to put a third solar panel up where would it go? I have the factory installed Zamp solar (2 80W panels with one expansion port).
Thanks in advance.
GloryBound is offline   Reply With Quote
Old 03-10-2019, 03:30 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Dometic A/C
Rear bedroom is the 13.5k with heat pump - part number 641835CXX1C0
https://www.dometic.com/en-us/us/pro...specifications
Front / midship is your 15k AC/heat pump part number 651816CXX1C0
Regarding solar panel location, well, you have lots of options on where to place your third panel if you want to fix to the roof. I have 8 100w panels up top of my 30’ international. Picture attached regarding optimal placement of panels...
Others choose to expand their systems using portable panels with separate charge controller, which are setup on the ground, and connected via the Zamp connector at your front battery box.
wulfraat is online now   Reply With Quote
Old 03-11-2019, 07:01 AM   #3
2018 30' Classic
Thank you!
I appreciate the timely and detailed response. I'm trying to plan some upgrades. Probably not 800W.
So far, my plan is for Lithium, micro air easy start and maybe a new charge controller.
Cheers,
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Dometic Furnance Help cmgirdwood Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
