07-31-2018, 03:55 PM
2015 25' Flying Cloud
Moab
, Utah
Fan-Tastic fan rain closure problem
We have a 2015 25' Flying Cloud RB. We love it. Fantastic fan closes with rain gauge but it does not close completely (last tiny bit). I have to click it closed with switch and then click it again to re-open. Even cleaned and waxed the edges of both. Still the same.
Our old 2003 23' International's Fans would close and then re-open. Great.
2015 Fans do not re-open. Should they?
Thanks for any input from Too Darn Hot Moab, Utah
07-31-2018, 04:14 PM
1995 25' Excella
xxxxx
, xxxxxx
I put a new one in my trailer in 2016. It closes up tight.
07-31-2018, 04:32 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Ours is a bit hit or miss on closing tightly. I have never noticed it re-opening once it closes.
Overland Adventurer
2009 34' Panamerica
Telluride
I believe ff suggests yearly silicone on the rubber gasket.
Perhaps the lift arm has become bent, and it's travel is now off?
07-31-2018, 05:22 PM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
The older FF's (pre-2014)used to re-open after moisture dried. Now they don't.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
07-31-2018, 05:26 PM
1969 25' Tradewind
Shasta Lake
FF does not reopen automatically . It only Closes when it senses water.
07-31-2018, 06:40 PM
2019 30' Classic
Canfield
, Ohio
Camping world sells some very nice white FF covers. Then who cares if it's slightly open. $49 a piece. Installs with the same 4 bolt holes AND, you can keep your fans running when it's raining!
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
07-31-2018, 08:01 PM
2007 22' International CCD
Corona
Data point: 2007 front fantastic fan drives me nuts opening and closing automagically in high humidity in Alabama. Ended up turning it off. I have a cover over the aft one. Less silliness with it. But still does it occasionally even after I clean the sensors.
08-01-2018, 09:50 AM
2011 28' Flying Cloud
Eau Claire
, Wisconsin
We have a 2011 FC 28. The front fan catches once in a while. I observed a few cycles, then used some pliers to squeeze the edge of the seal just a bit so the cover cleared.
Our fans do close and re-open, but you need to have set the direction switch so the default is open - I think. I've never really figured out the logic of the FF system!
08-01-2018, 10:07 AM
2014 25' Flying Cloud
Comox
, British Columbia
Depends on the age of the FF. Mine will close and reopen on its own. Apparently newer ones will not.
08-01-2018, 10:17 AM
palm beach gardens
Yes, Fantastic Fans are a bit of a magic trip, unfortunately I'm not a good magician, but I do like the show.
08-01-2018, 10:59 AM
2019 30' International
Pennsylvania
, Pennsylvania
make sure the plastic tab on the fan lid is seating square on the plunger switch.
08-01-2018, 11:20 AM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Our 2014 does as soon as the rain stops. Or at least it did until I put vent covers on. Now it doesn't matter.
George
08-01-2018, 12:50 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
If you rely on auto close for your FF, don't forget to place the fan speed switch to an "on" position. If left in off it cuts the power to the auto closing circuit.
guskmg
08-01-2018, 06:17 PM
2014 30' International
DFW Airport
My 2013 reopens.
08-02-2018, 09:05 AM
Moab
, Utah
Thanks to all who took the time to help me get this sorted out. Loved our old 2003 FF that closed and re-opened and also had a switch of bring air in. Oh well. Grateful in any case.
08-02-2018, 09:15 AM
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
When I was having a problem with mine and wanted to be able to change air direction, I called FF people and they helped me out with 2 new switches and schematics for the replacement. Now I can have one push and the other pull air. It was an easy fix. Give them a call.
08-02-2018, 09:25 AM
2018 30' Flying Cloud
Gig Harbor
I second getting a cover, which will allow you to keep the vent open while towing and keep the AS aired out. Not to expensive and easy to install.
08-02-2018, 10:08 AM
2007 25' Safari FB SE
North/East
, New Jersey
Call FF service, they have always been great in helping me out with problems.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
08-02-2018, 10:38 AM
2017 25' Flying Cloud
Fayetteville
, Arkansas
After checking their website, seems that some models with the rain sensor only shuts the lid. There are other models that shuts and reopens. Can anyone confirm that AS is not using the close/reopen models on newer builds (2017 AS)?
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
