07-17-2018, 04:58 PM
#721
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Keep in mind the Alde is set to accept 50psi while the coach pressure is set to 60#. Checked into a campground last night with 70# psi even trailer could not control and no having been out in a while forgot or exterior pressure regulator. Turned water on and water flowed out the Alde fresh water outlet. Connected pressure regulator all good
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
07-18-2018, 09:49 AM
#722
2018 30' Classic
2008 27' Classic FB
Oak Harbor
I'm pretty sure that we were told that our 2018 30' came with a pressure regulator that was built in. Not so Paiceman?
07-18-2018, 11:33 AM
#723
ObviouslyKnot
KAILUA
, HI
All true, built in supposedly is set at 60 and safety valve on alde is 50.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
07-18-2018, 12:28 PM
#724
2007 22' International CCD
Corona
Standard Airstream built-in "water pressure regulator" is nominally set to regulate to 60 pounds max. IMHO, it's a cheap regulator on the back of the water connection, and, at least on my rig, is darn near impossible to reach and work on, since the shower enclosure blocks access to the rear. So I basically don't even pretend to trust it...
I'm not surprised that the Alde system is rated to 50 pounds, and after that it dumps. I shan't comment on the blatant engineering/specification failure on Thor's part this is prime evidence of.
However, there is a very practical reason to use an external, quality water pressure regulator on ANY trailer hookup. A water hose, in the hot sun, gets warm, if not hot. Plastic gets soft when it is hot. Campgrounds often have unregulated water pressure to the point that some warn of very high water pressure. So a regulator screwed right to the campground spigot, then to your water hose, is a darn good idea, and that regulator should have a gauge on it so you can see what the pressure is in the hose and your trailer water system...
So get a good regulator, set it to 50 pounds or LESS, and use a filter on the other end of the hose to get the 'big chunks' out of the water and keep your faucet and shower strainers clear of sediment. You will spend a few bucks, but avoid a boatload of problems...
This is the regulator I prefer to use. No, it's not real cheap, but neither is my "troubleshoot and fix plumbing time" when I'm on the road:
https://www.amazon.com/Camco-40058-A...sure+regulator
And the water filter with a short flex hose (2-pack):
https://www.amazon.com/dp/B0722QJQMW...=2262876100701
And, just because I love to keep the filter from bending the side of the Airstream, an elbow to make it tidy:
https://www.amazon.com/Camco-Degree-...082NJFKBRY6EDN
This stuff, In MY opinion, is nice to have to make hookups easier and safer. We're talking under $100 for the lot if you use Amazon Prime...
Still, when you leave the AS unattended, its a darn fine idea to shut off the water spigot and release the pressure in the hose. You can't detect a leak in your water system if you are not hanging around and paying attention...
07-18-2018, 01:38 PM
#725
Upper St Clair
, Pennsylvania
Per James, spot on.
I use a good quality external and forgot to put it on as stated. And yes Alde dumped
07-18-2018, 01:58 PM
#726
Corona
---I rest my case, your honor.
07-21-2018, 03:17 PM
#727
Anywhere
, Alabama
Okay folks. Need your input. Noticed Alde pump was running and that led to seeing that the Alde thought the room temp was 43 F. That’s right, F not C. So took controller off wall and opened back and found that the remote sensor wire connector was loose and not fitting tight on pens of circuit board. Tried spreading pens apart a little to get more friction fit but to no avail. Can’t see anything broken off that snaps into connector. Thoughts ?
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
07-22-2018, 06:30 PM
#728
Cave Creek
I had nearly the identical experience this past week. I pulled out the controller and found the remote sense wire loose - but I just snapped it back in and everything worked normal. Sorry to hear yours is still not working. I suggest calling Alde US - they can diagnose better than the airstream folks
Pete B55
2017 Classic
2017 F-250
07-23-2018, 08:03 AM
#729
Anywhere
, Alabama
Well we were only 3 hrs from the mothership so we we came back. they sent a tech to our rig at the Terraport and he put a drop of superglue on the plastic connector. Said they have to do that from time to time. Oh well. At least it’s fixed for now.
Matt & Pam Padgett
Anywhere, USA
07-23-2018, 09:25 AM
#730
2018 30' Classic
New York
, New York
So fun to run into you at the Terraport! Hope you got everything up and running well today!
07-26-2018, 06:28 AM
#731
2018 30' Classic
New York
, New York
Originally Posted by ajwbarnard
I was thinking as I was taking a shower this morning in beautiful, hot water, how much I like my Alde and its ability to give me more than hot water than I have needed. The struggle to get there was real and this thread helped us finally get it working. But I now can enjoy it!! Now to get a few other things working as well as the Alde.
I just wrote this a week and a half ago. And then I went to JC for warranty work. They upgraded the Firefly panel and moved my Alde panel to a more visible spot above the silverware drawers under the sink. Still way back in there but not behind the water/drain pipes.
This morning I hit the shower boost in the bathroom only to come back from walking the dog to find out the new front panel had both gas and electric off. I guess the back panel does not communicate with the front panel that it needs to control the heat source anymore.
And on top of that, the water was lukewarm at best. Now it is back to troubleshooting. For those of you who regularly look at your Alde panel, what should the settings be for the hottest water? I had stopped looking because the old Firefly was taking care of the Alde pretty well. I haven’t done anything to the mixing valve so this is a Firefly/Alde thing. I am sure in moving the panel, the Alde was reset to factory defaults. I just don’t remember changing anything except to recalibrate the air temperature.
Any thoughts?
07-26-2018, 09:37 AM
#732
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
We just did showers this morning. Punch the Alde panel to "boost" and turn on both the electric and propane. Hit the service menu and watch the "sanitary temperature" head up. We wait for > 135F. You also could just wait for about ten minutes.
With "cold" water around 55 F and the mix valve set as we have it, a hot shower = shower valve about 30 degrees off of the bottom end.
07-26-2018, 10:29 AM
#733
2018 30' Classic
New York
, New York
Hi
I can watch the temp go up much easier now, but it didn’t get that high. I will have to play with it. We were used to it working with the push of the button. I will have to see if I put the controls for electric and gas on, if the bedroom Firefly will operate as it once did.
07-27-2018, 07:03 AM
#734
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Simple answer is to punch the button and come back in about 20 minutes. Take a look at what it reads then. Once you know what yours gets to at the tail end, you will know about what to wait for.
Normal idle on ours ( no button punched) is 120F on both temperatures. When boost gets hit the heater temperature rises past 150F. Again, it's not clear how accurate the sensors are so I'd take all those numbers as relative rather than absolute.
07-27-2018, 03:05 PM
#735
Reads a lot
Titusville
Ditto what UB said. I hit the boost then wait until I see the sanitary water temp hit 145 or higher. (about 15 minuets) depending on outside the AS temperature.
I would think that when that panel was moved the tech did reset the system which should not be an issue. I have reset my Alde a couple of times without any problems.
As long as the sanitary water temperature is going up then adjustments if any or pretty straight forward. I would be very surprised if your mixing valve suddenly failed but the tech may have adjusted the mixing valve setting to the manufacture specs which IMO is way too low.
Lauri
She Believed She Could so She Did.
07-27-2018, 03:55 PM
#736
Upper St Clair
, Pennsylvania
I have minimal confidence in the temp readings on the Alde panel as with our shower boost on in warm weather we often hit 165f in the sanitary readings
08-03-2018, 06:27 AM
#737
Green Cove Springs
We just had our trailer at JC for warranty work. Like many here, when we took delivery of our Classic it took months to finally get the Alde dialed in with the help of this thread. We have enjoyed plenty of hot water since. Well, the tech at JC decided he new better and reset our mixing valve to factory specs...even though I did not have anything on my list of repairs regarding the Alde or a hot water issue. I got a blank stare when I asked him why he reset it. The reset caused our hot showers to drop to about 4 minutes. I have been working to get it back where I had it but have been unsuccessful so far. I did get it back to about 6 to 7 minutes, but not back to 10.
Breathe In, Breathe Out, Move On
08-03-2018, 07:41 AM
#738
Airstream Ambassador
Jackson Center
, Ohio
Hi mojoe7009,
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
08-03-2018, 09:02 AM
#739
Upper St Clair
, Pennsylvania
That sucks, I watched and did not allow the "dial" to be touched nor the shower handle - but then I have no anti-scald set screw in our shower handle any more. So, ours still runs about 10 minutes per shower, then wait a couple of minutes and second shower same 10 minutes and it can be scalding hot if not careful. Good luck.
08-03-2018, 04:13 PM
#740
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
We both did showers back to back this morning. There still was *plenty* of hot water left after the second one. Gray water tank went up from about 35% to about 50%. For us that's a *lot* of water to use on showers ....
