Originally Posted by OriginalMrT
We noticed this weekend that when opening the big front and rear windows that when the bar is placed in the first notch position (from the bottom) the windows remained closed, loose but closed. We are wondering if the J channel was put in wrong or if it is a common affliction.
I have this problem with the two big side windows across from the entry. But one is worse than the other. The one closest to the dinette never stays open on the lowest notch (it's like yours, loose but closed) but the one closer to the fridge does stay open on the lowest notch until there is a breeze, then it closes itself (and is hard to reopen with the latch stuck in the low notch!) Took it to the dealer and they said it just needed to be tightened. That didn't change anything. I just stopped using the lowest notches. I don't have a problem with the big front and back windows.
I'm not a fan of these windows. They seem easily damaged. I like normal sliding windows much better. Can't count the number of times I've had to close them in wind when I couldve easily left em open if they were normal windows.
