10-04-2012, 02:08 PM
Airstreamer
2012 27' FB International
Bellevue
Lug Nuts on a new Airstream & Tightening
We have towed our new Airstream a good amount of miles and in the brochure it recommends that we tighten the lug nuts every 50, 100, etc. miles.
They say that the pounds of pressure on the lug nuts should be 110#
If you are doing this yourself, how can you check? I have tried to tighten the lug nuts myself (am a girl) and have turned them as hard as I could and have never felt any "give."
At what point is it when you don't have to worry about tightening them anymore??
Thank you in advance (again) for all of your help and suggestions!
{blog} ★ Just 5 More Minutes to Enjoy Non-Stop Outdoor Adventures and Culinary Discoveries in the Northwest with our Airstream ★Blogger for GoRVing.com
10-04-2012, 02:11 PM
Fremont
First of all I think most new Airstreams were delivered to the dealer after being towed from Ohio. I know in my case the trailer probably had 500 miles on it.
That being said I carry one of those four sided lug wrenches in my truck and before each trip I check each lug nut. I don't have a torque wrench but like you I check to see if there is any give, thus far I have not found any.
"The bad news: there is no key to the universe.
The good news: it was never locked."
Swami Beyondananda
https://polakoff.com/RamblinRose/
Our travel log
10-04-2012, 02:15 PM
2012 28' International
New Orleans
, Louisiana
Buy a torque wrench and learn how to use it. I carry one of these with the correct socket and extension. Wait for a coupon then buy the wrench. They are girl friendly.
1/2" Torque Wrench
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
10-04-2012, 02:38 PM
Oswego
Once a new wheel and lug nut is seated well through use, it is not as critical as it is when first mounted and through the next couple hundred miles. I would add that this procedure should be followed after any rotation or remounting.
Like others, after the first couple hundred, I have never found one to budge under specified torque.
-Rich-
10-04-2012, 02:52 PM
Wise Elder
2010 30' Classic
South of the river
I have a wrench that looks just like Jim's and use that occasionally to check the bolts.
Any tire shop will check them for you for, at most, a nominal fee.
10-04-2012, 05:13 PM
Salem
, Oregon
Hi, always use a torque wrench; Too tight or too loose is not good. I check lug nut torque and tire pressures just before each trip. If for any reason that I have to completely remove a wheel, I torque the lug nuts when I put the wheel back on and one more time at the first rest stop.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
10-04-2012, 06:27 PM
2012 25' FB Flying Cloud
Celina
, Ohio
For those of you that check your lugnuts on the AS, do you also check them on your TV?
If not why not? In over 40 years of driving I have never checked the torque on my car and never had avwheel come loose or fall of.
Gary
10-04-2012, 07:21 PM
Oswego
As I said, not so critical after a seating after initial use. You should check you vehicle after some miles after a rotate. Rust and scale can be lodged in between the wheel and hub, work out during driving and leave lug(s) loose. Not too common, but we've all see that 3 wheel wonder by the side of the road and wonder.........just what caused that?
-Rich-
10-04-2012, 09:55 PM
Salem
, Oregon
Originally Posted by Castaway
For those of you that check your lug nuts on the AS, do you also check them on your TV?
If not why not? In over 40 years of driving I have never checked the torque on my car and never had a wheel come loose or fall of.
Gary
Hi, Gary. Before any trip while pulling my trailer, I torque all of the lug nuts on my tow vehicle and trailer. I also check tire air pressure on both too. With the old fashioned steel wheels, there was almost never a problem, but with aluminum wheels, they need to be checked.
10-05-2012, 09:25 AM
Airstreamer
Bellevue
Thank you everyone!!!!!!
10-27-2012, 09:08 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Don't forget to put anti-seize compound on the stud threads - that wil DRAMATICALLY change the torque on the nut / stud. In a pinch I use a very small bit of grease on the studs.
10-27-2012, 09:33 AM
2002 25' Safari
Fountain Inn
, South Carolina
Gary
I asked the same question once of someone who has towed many more years than me. His answer focused on the side torque that trailer wheels go through (as opposed to tow vehicles) and how this can effect trailer lug nuts. He felt that even more torque wrench attention needed to paid to aluminum wheels.
I check my lug nuts with a torque wrench before each trip and each traveling day when I am traveling on long trips. Same with tire pressure.
Bud
10-27-2012, 09:37 AM
2002 25' Safari
Fountain Inn
, South Carolina
There are mixed opinions on any lubricant on wheel studs. I do not ever lube wheel studs because I think it can result in over torquing the lug nuts. I run a thread chaser over threads that need cleaning up.
Just another point of view. Do a search on the web for various views on lubricating studs.
Bud
10-28-2012, 07:12 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
My 2013 Int'l 25FB was trucked out to Los Angeles from Ohio. At the 20 mile mark on the way home, I pulled over and 5 out of 6 lug nuts needed to be tightened on all 4 wheels. I also had to check the Hensley Arrow u Bolts. I then checked at about 50 miles and several lug nuts needed just a little more wrench action. I then checked at about 140 mile intervals for the next three stops and they were all okay.
I plan to check them before each run day just to be sure. One should also check tire pressure every morning to ensure a last minute "acquired" nail had not finally penetrated the tire overnight.
10-29-2012, 04:56 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Torque'r......
05-30-2016, 06:30 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
WHOA THERE!!!
If you use anti-seize with a specified 'dry' torque, you can pull the fastener assembly apart.
Only 10% of the applied torque (dry) is used to actually tighten (stretch) the stud. the rest is used to overcome friction: 40% at the nut face, 50% in the threads. You take away that friction, you had better know how much to REDUCE the torque.
Even using oil on the threads calls for a 20% reduction in TORQUE to achieve the proper TENSION. (Wiping a dry bolt through a head of 'greasy hair' will do the same.)
ReTired Cdn. AME, and former agent for Premier Fastener Corp.
