09-22-2014, 04:29 PM
2012 25' Flying Cloud
Berlin
, Maryland
How campers have evolved
I apologize if this will not open as it is a powerpoint presentation
RV Evolution.pps
09-22-2014, 05:13 PM
Broadway
, North Carolina
did not open can you convert it or retry?
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
09-22-2014, 05:33 PM
I'm In
, Kentucky
RV Evolution.pps
doesn't look like it attached. Can you "zip" and attach? Maybe that will work
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
09-22-2014, 05:50 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Or publish as a PDF from Power Point?
09-23-2014, 04:09 PM
Berlin
, Maryland
I am not sure how to convert or zip it. If I ama ble i will resend
09-23-2014, 04:35 PM
I'm In
, Kentucky
If you have Windows 7 (maybe XP too) just right-click the file, choose ' send to' and compressed zip folder. It will put it into a zip file, then choose the paper clip icon in the top row of the message screen. Navigate to the file, select it, choose upload, close the window and publish the message.
-Rich
Rich & Yvonne
09-24-2014, 06:35 AM
Berlin
, Maryland
I have a MAC but I have never converted a file to a zip file. I will explore.
09-24-2014, 06:44 AM
I'm In
, Kentucky
I don't know anything about MACs but it's probably very different. Can you try just attaching the PPS file to your message again?
-Rich
Rich & Yvonne
09-25-2014, 10:58 AM
Berlin
, Maryland
RV evolution
This appears is the best I can do. I wish I knew the source
<RV Evolution.pps>
09-25-2014, 11:18 AM
I'm In
, Kentucky
<RV Evolution.pps>
Sorry, still no attachment. I'm assuming you have the physical file on your computer? I wish I knew more about MACs. My old Apple //e is still in the closet but that's as far as I went with Apple products.
-Rich
Rich & Yvonne
09-25-2014, 10:42 PM
Mohnton
, Pennsylvania
RV Evolution.pps
Is this the link you were trying to post?
http://photos.msn.com/slideshow/auto...uture/23aqp0m9
09-25-2014, 10:55 PM
Durango
It is very easy.
You can right click on the file and select "compress" from the pop-up menu. This will generate a standard zip file.
If you don't have a two button mouse or your track pad is not setup for "right Clicks" just put your cursor on the file name, hold down the "control" key and click the mouse. Now select "compress" from the pop-up menu.
