04-14-2010, 08:37 PM
2007 31' Classic
Bend
, Oregon
A/S Roof
Why is the roof on newer A/S painted white? Is it paint or some other substance? When did this practice start?
04-14-2010, 10:07 PM
1977 27' Overlander
Trotwood
, Ohio
White reflects the sun. Cooler inside.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
04-14-2010, 10:19 PM
Ottawa
, ON
And I think it's fairly recent, jfowler218. By recent, I mean the '90s.
it's a very special paint, apparently, but Mike is right, it's supposed to make a big difference in the internal temperature of your trailer.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
04-14-2010, 10:57 PM
1999 25' Safari
Fairburn
, Georgia
Not to mention, scratches and blemishes on the aluminum skin can be covered up with white paint, but not with clear coat.
04-15-2010, 05:22 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
Our '97 Excella has the white roof.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
04-15-2010, 07:37 AM
2008 28' Safari SE
winter garden
I believe its actually white anodized aluminum
04-15-2010, 10:01 AM
1994 21' Sovereign
Tucson
It's not anodized, it's painted. Depending on binder formulation paint with titanium dioxide pigment can reflect up to 97% compared to about 80% for bare aluminum.
04-15-2010, 12:10 PM
2008 28' Safari SE
winter garden
OK, Thats not what Airstream told me, but they could be wrong
04-15-2010, 04:07 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
I painted my 77 roof white. It helped in the sun at Rapid City. We did not have 30 amp service in those days and we had to rough it. The Airstreams after 1995 when they went wide body bought a prepainted aluminum from Alcoa. I think it is acrylic based. At the same time they started buying preclearcoated aluminum for the endcaps and sides. The coating did not work out so well and they had to recall and repaint quite a few under warren-tee when they started to fail within the two years. I think the underlying material is just straight aluminum rather than the Alclad laminate of the pre1964 trailers.
04-15-2010, 07:01 PM
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
The current white roof began in 1994 when the shape changed to a slightly more square profile. The roof panels are prepainted by the supplier before shipping them to Airstream (they definitely are not annodized - I know, because I've scratched mine on the '94 Excella while removing and redoing caulk around the roof vents).
1993 models with the older slightly more rounded profile still had silver roofs.
As a historic note, in the late 1950's through the early 1960's, Airstream offered an option for a white painted roof (Egyptian White?) to help keep the interior a little cooler by reflecting more light. You can see several such trailers in photos of the 1963-64 Around the World Caravan.
P.S. The switch to the wide body profile started on some 1995 34-footers and then on all trailers 25-foot and longer for 1996.
Joe
WBCCI/VAC #702 & #6768
04-15-2010, 09:38 PM
2016 27' Flying Cloud
Georgetown
Is that paint available for purchase? If it is available for purchase, where? Would there be any reason for discouraging someone from purchasing it and painting the roof of a 1988 Excella? Bad idea? Or ok idea?
04-16-2010, 12:53 AM
Mike, on the older (and much prettier, IMHO) shape, parts of the white roof can be seen from the ground, whereas it is much less obtrusive on the post 1995/6 "flat tops". That's why I won't paint white the roof on our trailer.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
