Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 11-14-2010, 07:35 PM   #1
2007 28' Safari SE
Anchorage , Alaska
Tweeked Steps
We recently bought an 2007 Safari and the steps are tweeked. They work but need some swearing to get them pull out sometimes. How would you fix this?:
ID:	115276   Click image for larger version
ID:	115278   Click image for larger version
kcbwil is offline   Reply With Quote
Old 11-14-2010, 07:46 PM   #2
Naples , Florida
REPLACE THEM!
Unless you are VERY GOOD with metal and are able to remove the steps, re-shape to the original pattern and then re-install them, they will never work as original. They don't cost that much and I'm sure you will spend the better part of a day messing with them and get sub-standard results. What is you time worth?
lewster
Old 11-14-2010, 07:50 PM   #3
x
XXXX , XXXX
In relation to your other post about the hole. The angle of the bend in the step matches with the impact to the side wrap.
I'm with Lew just replace the steps. I have tried in the past to repair bent steps on several rental units and they never come out as good as new.
wasagachris is offline   Reply With Quote
Old 11-15-2010, 09:59 AM   #4
2007 28' Safari SE
Anchorage , Alaska
Steps
We're in Alaska. What brand of steps do u recommend and where can I buy a good set of steps?
Thx for yr replies.
Old 11-15-2010, 10:03 AM   #5
Ottawa , ON
Airstream in Jacksonville Center stocks and sells them.
Could be wrong, but I don't think that's something a dealer would keep in stock...
Old 11-15-2010, 09:32 PM   #6
2007 28' Safari SE
Anchorage , Alaska
Many thx....
I appreciate the advice, seems a new step is the best choice. I'm sourcing a step and, barring problems, come spring they'll be mouted. Thank you for yr help.
Old 11-15-2010, 10:52 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Thanks, now I don't feel so stupid about what I did to mine. Guess I'll look at CW first. Might be in Ohio in Jan. Are these easy to install for a do-it-yourselfer?
Paula
Old 11-15-2010, 11:38 PM   #8
1960 22' Safari
in the wilderness , The great Mojave Desert
Camping world sells them. They just don't sell that color.
I bent mine and then using a chain, sledge and another tow vehicle I got them mostly straight and they work fine.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 11-16-2010, 05:56 AM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I had the same problem with Lucy's steps. The still worked but were crooked. I recently got a new set at Camping World. They have a curved front, and I like them much better than the originals. The CW Catalog number is 37039, and the Club price is $69.99
Brian
ID:	115340   Click image for larger version
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 11-16-2010, 08:43 AM   #10
Aage.
By agreement with it's dealers, Airstream will not sell repairs parts to someone unless they are in Jackson Center.
Dealers many times order parts that they normally don't stock, and then have them "dropped shipped" to the customer.
However, the purchase must be a certain minimum amount, and if not, Airsteam adds a "handling charge", because of the paper work involved. Typically, that amount could be as high as $200.00, exclusive of shipping or tariffs.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-16-2010, 09:13 AM   #11
Ottawa , ON
Funny, I saw them on the shelf in the Wally Byam Store there, with a price tag on them.
Old 11-16-2010, 09:28 AM   #12
2005 28' Safari
saline , Michigan
Thanks Brian,
Great tip at Camping World. Mine are bent also and in my shop where I am trying to figure out how to straighten. I can do it but it is going to be way easier to put on a new set at $70.
john
Kosm1o is offline   Reply With Quote
Old 11-16-2010, 09:54 AM   #13
Aage.
Anyone can buy anything from Airstream, "BUT" they MUST be in Jackson Center.
If that person is "NOT" in Jackson Center, then the answer is "NO".
That's why you see many things in their store, but only a limited number of them can be purchased via the phone and shipped out.
This is as per the dealer agreement that Airstream has with it's dealers.
Airstream requires dealers to stock a certain dollar level of parts. They then, work with the dealers, so as not to compete with them, "EXCEPT" when that person is in Jackson Center.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-16-2010, 10:24 AM   #14
Ottawa , ON
So, what you're saying is that my original post was right: they stock and sell them.
Thanks!
Old 11-16-2010, 10:30 AM   #15
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Why not have a try at fixing them before spending $$ on a new set? If you are prepared to buy new anyway, then no harm done if, in the worst case, you make the ones you have worse! instead of better!
You should be able to see what is bent or misaligned and some judicial bending or hammering with a soft faced hammer may well do the trick - you may not even have to dismantle them.
I managed to bugger ours up by leaving them down while pulling away from our driveway and ripped up several feet of sod along the curb!
Steps wouldn't work after that and I was pretty mad at my stupidity!
I had a go at them along the lines I described and they are fine again now. Not even any evidence of my mishap!
Mine are the aluminum double folding stype, but should be the same to fix the steel ones - maybe easier.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-16-2010, 10:40 AM   #16
Thanks!
Yep, but how they must sell them is important too.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-16-2010, 11:35 AM   #17
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
IF you have the shop and or heating type equipment and a big hammer and an anvil. Id GOT FOR IT. You dont have anything to loose. They dont work anyway so ya aint out nuffin. SO WHAT if ya wind up replacein em,you was gonna have too anyway.
GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
New Steps Chaplain Kent Classic Motorhomes 1 08-16-2007 08:44 AM
Steps Cap-N-Red 2000 - 2004 Safari 11 06-07-2006 05:47 AM
Steps Devoman Steps 3 12-16-2005 08:44 PM
steps lmbando Steps 18 03-25-2003 08:30 PM
Steps Texas Steps 6 10-31-2002 10:50 PM
