02-26-2013, 11:35 AM
Spring town
Pin striping on a '73 Overlander
Has anyone ever found were to get original blue pin striping for a 73 overlander? I'm about to give up looking,thought about trying to paint it back on it's the only thing I can come up with. Also it's not the blue insert it's pin striping material. Any help would be appreciated!
02-26-2013, 12:35 PM
1966 26' Overlander
Woodstock
, Georgia
CHECK EBAY. I striped three of our Airstreams with marine grade stripes I found there. You might get that color or very close. I chose to use my own color scheme and match the awning to it. Here are a couple..
02-27-2013, 07:29 AM
Spring town
Ok great thanks for the info, did you use the vinyl?
02-27-2013, 08:19 AM
1972 25' Tradewind
Chattanooga
, Tennessee
I masked and painted the stripes with rustoleum royal blue. It came out well.
02-27-2013, 08:44 AM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
If you go to a sign shop, they can cut the stripes for you. The closest blue I have found is called Traffic Blue. Hope this helps.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
02-27-2013, 12:30 PM
1966 26' Overlander
Woodstock
, Georgia
I used vinyl striping. I have bought large rolls for under 20 bucks. Had enough to do two trailers with the same stripe off one roll.
02-27-2013, 03:26 PM
Spring town
Great thank you so much! You've been a big help!
02-27-2013, 06:32 PM
1972 31' Sovereign
Fort Bragg
, North Carolina
Have you looked at either Inland RV or Out of Doors Mart web site for the striping you need or can change? I had all of the original 1 to 1 1/4 done on our 72 International and am going to recover the 7.5 inch stripes that are on the propane cover in front. Don't know if it helps as i am looking for two of the International Emblems for both roadside and curbside to replace on our 41 yo coach. Guess this stuff eventually wears out with use.
SL4BLLT
03-02-2013, 04:13 PM
Spring town
Alan
Thanks for all the info I did fine them at eBay marine I appreciate every thing !
03-02-2013, 04:15 PM
Spring town
SL4BLLT
I had looked at both places before and neither one carried it but thanks a lot !
