Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 03-08-2019, 06:54 AM   #1681
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Have a 6' tape measure in the bag with the tools for the jack and hitch. Grab tape and the three wrenches. I use the Airstream supplied manual speed wrench to take up the slack or loosen and then the PP supplied ratchet to fine tune. At least I get some arm exercise in the process. If there is unusual resistance in the screw jack, I can feel that with hand tools where a power drill might cause damage. I found a lonely combination Craftsman 15/16" box wrench in a closeout store I use for the over center locking nuts. Great leverage as it is maybe 14" long.
I also carry a half dozen spare spring retainer clips in case some one borrows a set while I am away.
Old 03-08-2019, 01:38 PM   #1682
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
I have to admit that I have not read every post in this thread, but it’s time to join the Propride Club. I bought a 2019 F250 Platinum and my wife ( and I) was uncomfortable with the loose and wandering feeling when towing our FC25FB with its Blue Ox SwayPro. We towed with the SwayPro for 30,000 stress free miles behind our Titan XD Diesel. After trying everything possible to make the SwayPro work with our new F250, we decided to try a ProPride. We bought a used hitch after a conversation with Sean stating he fully supports buyers of used hitches.
Yesterday we installed the hitch. Today we test drove various weight distribution settings 6”, 6.5”, 7”, and found our sweet spot at 6.5”. My wife stated that with the ProPride at 6.5” of weight distribution it now feels like the truck is in control and not being pushed around by the Airstream. That is exactly what we hoped to accomplish with our newly installed ProPride!
ID:	335172   Click image for larger version
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 03-08-2019, 01:59 PM   #1683
2007 22' International CCD
AirMiles, that exactly what I found out on my rig. The ProPride flat made the whole setup ride much better. Admittedly my Tacoma is a bit light for the 22 International, but now it rides like its on rails, assuming I have the WD set right. It's easy to tell if its wrong, DW gets seasick from the porpoising on the front of the truck. A bit more tension on the jacks cures it, around 1/4 to 1/2 inch or so.
Old 03-08-2019, 02:33 PM   #1684
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Originally Posted by SteveSueMac View Post
Al - I have the 2.5” stinger - it’s about 60#....the reducer sleeve and 2” stinger may be worth keeping [emoji3]
Thanks! I have thought about getting a friend with welding equipment to shim it up with some sheet steel. I can't think of any reason not to do that, and it would be a lot lighter (and cheaper).
Al
Old 03-13-2019, 09:49 AM   #1685
ObviouslyKnot
james.mileur's Avatar
KAILUA , HI
Not sure what folks have made themselves - here’s what PP sells for that: https://www.propridehitch.com/propri...locking-plate/
Airstream of Spokane had this rig. Be sure to pin the shank to the rig. Click image for larger version
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 03-13-2019, 10:12 AM   #1686
ObviouslyKnot
KAILUA , HI
Originally Posted by AirMiles View Post
I have to admit that I have not read every post in this thread, but it’s time to join the Propride Club. . . .now feels like the truck is in control and not being pushed around by the Airstream. That is exactly what we hoped to accomplish with our newly installed ProPride!
AirMiles, welcome aboard the PPP train. You will have no regrets. May I encourage you to do two things?
1. Carefully read through installation manual and second check everything. Especially, centering the rear yoke bushing. Check all fasteners tight again after maiden run.
2. Go back a couple years in this thread and read to date to just immerse in the corporate knowledge available. Skip the ranting and comparisons. I was on my second PPP when I did this all the way back, and learned a lot.
And Sean is the best.
Old 03-13-2019, 03:52 PM   #1687
AirMiles's Avatar
I've been reading through this thread. I read about 700 posts from the beginning and about 700 posts back from the end and learned some tips that I wanted to try.
So today I did a double check and tested the tips. Found the 250# bolts were way looser than expected. I bought the hitch used and thought they were torqued by the previous owner. Torqued them to 150# (max of my torque wrench) and then gave them another 1/4 turn with my 30" breaker bar with all the strength my 240# body could muster. (Used the thread tip to jamb a chisel to hold the bolt). Also read that the yoke was supposed to be tighter against the frame bracket forks than my first attempt. Tightened the frame bracket bolt below the yoke so there was just enough space for the yoke to move up and down but barely any sideways motion. Also tried a few different washer arrangements, but preferred the weight distribution from two washers at 6.5". The test drives were done in 17 mph crosswinds, which is pretty stiff for a non-hurricane Florida day. I was completely satisfied with the towing performance of my rig in these winds with the Propride. Another successful Propride installation!
Old 03-14-2019, 09:31 AM   #1688
The unofficial pp users guide...
Strongly suggest getting a 250 foot pound torque wrench to be sure about torque on those bolts. They are holding the very important bits together.
Harbor Freight one is good enough. Just set to zero when not in use.
The frame bracket bolt is critical. Centering of that bracket is also important. Check it occasionally to assure good sway control.
Old 03-14-2019, 11:15 AM   #1689
AirMiles's Avatar
rmkrum, I just re-read the ProPride instruction manual about the tightness of the 3/4" yoke bolts. It states: "Tighten the 3/4” Bolts VERY TIGHT. These bolts MUST BE TIGHT. Torque to 200-250 ft-lbs. Repeat on both sides of Yoke."
I'm a healthy 6'5" 240# guy with a big 3/4" drive breaker bar that tightened these bolts about as tight as humanly possible without a cheater bar. I certainly reached the 200-250 ft-lbs of torque required on these bolts.
I appreciate your suggestions and will look into buying, or borrowing, a bigger torque wrench.
Old 03-14-2019, 11:33 AM   #1690
ObviouslyKnot
KAILUA , HI
2' chunk o' pipe over the beaker bar, pull up 120# from a squat position, wa-la, baby. I dropped big washers between the bolt flats and frame so not to have to remove that cover again. Or go to local diesel repair shop and ask for $5 rental of torque wrench. 2' of pipe is a useful camping accessory somedays.
Old 03-14-2019, 11:43 AM   #1691
Yeah, I’m not a little guy either. I like the reassuring ‘click’ I get from the torque wrench when I manage to hit full torque on those big bolts. Even with a pipe cheater it’s sometimes a struggle to get them tight.
My Engineering OCD is happier when I can measure torque instead of trying for “as tight as possible” on critical parts. The toughest part was holding the bolt with one breaker bar whilst I jumped up and down on the torque wrench when I first installed the hitch. Best hard work I ever did-it tows perfectly now.
Enjoy the ride...
Old 03-15-2019, 10:36 AM   #1692
SailorSam205's Avatar
South East , Michigan
I got my 250lb torque wrench from Lowes. Happy I have it, makes torquing wheels easy.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 03-16-2019, 06:52 PM   #1693
kpm
2018 25' International
Mound , Minnesota
I’ve been happy with my Tekton 50-300 ft.lb. torque wrench. $76 from Amazon.
kpm is offline   Reply With Quote
Old 04-28-2019, 01:30 PM   #1694
Issaquah , Washington
FYI, updated install manual posted in the Face Book ProPride user group, suggest joining that group for notices when updates are posted... Quick screen shot of socket and torq page.
Name:	PP torq specs.png
KirkAlm is offline   Reply With Quote
Old 04-28-2019, 04:15 PM   #1695
nryn's Avatar
2019 27' Globetrotter
Driftless Area , Wisconsin
Bummer. I am not on the Facebooks. Anyone care to repost or otherwise make available?
Airstream adventures and enhancements thread: Traveling with Tatay
Personal blog (photography, travel, woodworking, flyfishing, food): nryn.com
nryn is offline   Reply With Quote
Old 04-28-2019, 10:38 PM   #1696
Here is the one posted 4/28/2019, and you can always ping Sean on getting the latest.
Old 04-29-2019, 06:03 AM   #1697
nryn's Avatar
Thanks much!
Old 05-16-2019, 06:21 AM   #1698
WARNING: Battery Strap as Stinger Carrier
I copied the idea of a previous poster and am using a battery carrier strap as a handle for my stinger. Yesterday I noticed that the heavy grade piece that grips the battery terminal which I bolted to my stinger is attatched to the plastic strap with a loop of lighter gauge steel sheet metal. The loop has torn about half way through. At some point in the future it would have torn all the way and dropped the stinger, probably on my foot.
If you have also copied the previous poster, or me, inspect your carrier carefully.
Al
Old 05-16-2019, 06:34 AM   #1699
Peoria , Arizona
Best "Fresh" Install Guide I've Seen So Far
Excellent -
'24 Silverado 2500 Diesel 4x4 ZR2, 2018 FC 28W (Queen) Landmark Truffle, ProPride Hitch, 3" Dexter Lift, Centramatics
kb7our is offline   Reply With Quote
Old 05-19-2019, 06:32 PM   #1700
2020 Classic 33
Box Elder , South Dakota
Receiver/Stinger Carry Handle
Here's my solution for a carrying handle for the receiver/stinger. $4 3" C-clamp from Harbor Freight. Balances pretty well and makes removal much simpler. Since I have the 2.5" shank version it weighs in at 55#.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Looking at new TVs, Input please Mr & Mrs S Tow Vehicles 46 03-16-2012 10:39 AM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 09:44 AM
