I use a coupler lock to keep the tongue secured on the ball. I then leave the stinger (with Enkay Rock Tamer attached) to the opening of the Hensley, pull the pins securing the cams and use a padlock on either side to prevent the stinger from being removed. I then run the Class III/IV receiver hitch lock through the hole in the stinger. I plan on buying a Reese 2" receiver tube, welding the end away from the trailer shut, plugging the pin holes temporarily and dipping the receiver tube in a bright color liquid rubber dip. I can then slide this tube over the stinger which will keep the grease from getting on anyone's clothing, make it more visible so people don't knock their shins on it and make it harder to cut the lock. I'll post pictures when I get all this done. I'll leave the flaps of the RockTamer on while parked in my back yard but will probably pull them and the rods they mount on if I leave it at the hunting site.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
