03-11-2013, 09:03 AM
Common Sense
Hitch Height....yes, again.
With our new Dodge Ram truck and ProPride hitch, after proper weight distrubution adjustment, we end up with the trailer 1/2" low in the front, or if I raise the drawbar to the next level, the trailer is 3/4" high in the front.
Of the two, which would you choose and why?
Thanks in advance for your input.
Regards,
Steve
03-11-2013, 09:52 AM
Puyallup
loaded or empty
reminds me of a old joke:
you're measuring with a micrometer - marking with a grease pencil and cutting with a chainsaw, it's not an exact science
03-11-2013, 10:15 AM
2010 25' FB Flying Cloud
Davenport
, Iowa
You're within Government spec.
03-11-2013, 10:21 AM
2008 27' Safari FB SE
Miami
More better the trailer is a half inch low. Should be fine.
Mike
03-11-2013, 10:27 AM
Common Sense
Loaded, ready to rock and roll.
And, why do you believe that?
I like to think I'm better than "Government spec."
Regards,
Steve
2002 25' Safari
Dewey
I would go with the 1/2" low in the nose. The subject has come up several times and most people believe that a little low in the front is better then a little high. It may have to do with the aero dynamics going down the road, but I am not a rocket scientist.
My reason has to do with overnight stops when you leave the trailer attached to your TV. With the front a little low, you can just raise the front slightly for a level trailer and still be attached. If the front is high, you can not level the trailer easily.
Richard
03-11-2013, 10:29 AM
Common Sense
Makes sence, I like that.
Regards,
Steve
03-11-2013, 10:35 AM
Miami
Generally speaking, trailer a little nose low adds a mite to hitch weight some of which is transferred to the front axle, helps keep the steering geometry more or less in line.
With the trailer nose high, just the opposite happens. May still be fine but less likely. In either case, you are so close to level it is unlikely to matter much.
Mike
03-11-2013, 12:04 PM
Chief Chili Cook
2010 30' Flying Cloud
Bakersfield
If you can't hit level, I vote 1/2" low in the front for no other reason than because it gives you 1/2" more ground clearance in the rear.
The NSA -- The only part of the government that listens.
03-11-2013, 12:34 PM
1988 32' Excella
Robbinsville
, New Jersey
My vote is try it low in front, then check tire temps if the front is noticeably hotter change to higher in front and check tire temps again. Then go with the setup that has the tires closer to the same temps (same temps=even loads on tires).
03-11-2013, 12:42 PM
1988 32' Excella
Robbinsville
, New Jersey
Mike
I think this is only true without independent suspension on the trailer. With the torsion axles on the Airstreams when the front is lower the front axle is carrying more weight and the pivot point of the axles shifts forward which reduces tongue weight.
03-11-2013, 02:55 PM
Oswego
Steve, what's your tongue weight as a % of total with the front 1/2" low and everything loaded in truck and trailer. If you have some extra tongue weight (like 12 - 15% of total) I'd relocate some weight to rear of axle to lift the front a little at the 1/2"ow setting. But of course, never less than 10% tongue weight.
-Rich-
03-11-2013, 06:24 PM
Common Sense
Rich, If I discount the weight of the ProPride (I'm told on here that it's NOT counted as tongue weight, but I wonder), my tongue weight is about 850 pounds, or right at 10% of the trailer weight.
Regards,
Steve
03-11-2013, 06:40 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
How much drop are you using? It appears you have the adjustable hitch head with 1.25" centers on the bolt holes. Is there an option for a set drop from PP?
I do not remember, do you have the 15" or 16" wheels and tires installed? The 16" Michelins would add about 0.6" in height to the Airstream over the GYM 15" ST tires.
Another choice would be to add one or two of the three blocks back on to the top of each side of the rear axle to elevate the rear end of the truck.
Since one can replace the adjustable part for about $225, if all else fails, get the adjustable unit welded to the precise height and be done with the issue.
03-11-2013, 07:51 PM
2012 27' Flying Cloud
W
, New England
I've heard both as well (that the PP does and doesn't count toward tongue weight). What is the definitive answer?
03-11-2013, 08:12 PM
Common Sense
I don't know of a set drop option from ProPride, and I do have 16" wheels and tires.
The other two options you mention are possible, but to me, undesirable.
Regards,
Steve
03-11-2013, 08:14 PM
Common Sense
Whatever the answer is, the tow vehicle has to haul it, and I suppose it depends on whatever point is trying to be made.
Regards,
Steve
03-11-2013, 09:07 PM
1994 30' Excella
Mississauga
, Ontario
since the hitch is bolted to the trailer I think it is part of the trailer. Therefore tongue weight should include hitch. the weight of the hitch is being carried by the tow vehicle.
Al
Al and Jean
TAC ON-3
03-11-2013, 09:12 PM
Common Sense
Al
Actually, most of the weight of the ProPride is not bolted to the trailer, but is attached to the coupler as any other hitch would be. No matter, either way the tow vehicle must carry the weight.
Regards,
Steve
03-11-2013, 09:41 PM
1969 27' Overlander
SW
, Missouri
I'm pretty sure that the manual for my Overlander recommends that the nose be a bit high. It may be worth noting that the manual also includes detailed instructions on how to dig a sewage dump pit when boondocking.
I'm not totally convinced that these recommended practices are up to current specs... I guess if my trailer ever starts to sway or a ranger questions my disposal habits, I can point to my manual to prove 'em wrong!
