Old 07-01-2009, 11:56 AM   #1
1987 29' Sovereign
Washington , Washington, D.C.
Electric jack
I just bought a 1987 29' Sovereign and I need to replace the jack on the front of the trailer. There is an electric jack there that does not work. Can anybody recommend a model? I like the idea of an electric one, but do I really need it to be electric? Any help would be very appreciated.
Matt
mweir is offline   Reply With Quote
Old 07-01-2009, 12:16 PM   #2
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
MATT>>First before U junk the jack, Check for a bad breaker.Check for power at the motor.Broken wires have been know to happen. I think some of the power jacks are repairable. The PO of our 77 Overlander Junked the jack and I believe there was nothing wrong with it. In searching the breaker panel for another reason I found that the jack circuit was dead. I replaced the breaker in case I am able to afford a new electric jack. We are getting along without the Electric Jack for now. If I have a health problem where I'm not able to crank it I will replace it.Sorry I cant tell ya what jack is best.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-01-2009, 12:37 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Atwood seems to be the norm,first though,I would check out the one you have.Hand jacks are just a pain to get the Weight dist. hitch hooked up.Dave
easyride is offline   Reply With Quote
Old 07-01-2009, 12:50 PM   #4
1987 29' Sovereign
thanks to you both! it could be a bad fuse, the only problem is i had to get the airstream off the property where i bought it and hack sawed the tubing!
Old 07-01-2009, 12:58 PM   #5
easyride's Avatar
1977 27' Overlander
Naples , Florida
Jack
There was a lower unit on Ebay,may have went off by now. Dave
Old 07-01-2009, 02:44 PM   #6
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
You can loosen the top of the jack (this part is about 6"x2.5"x 3"high) and take it off. Leave the wires attached. Next you can manually crank the jack up or down. I had to do this for a few months on my 87 until I replaced the worm gear. That was about 10 years ago and things have worked fine since then.
62bam is offline   Reply With Quote
Old 07-07-2009, 05:28 PM   #7
SteveH's Avatar
Common Sense , Texas
What type of handle/crank is needed to manually turn an electric jack with the power head removed?
Old 07-07-2009, 05:58 PM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
It is a simple cheap crank deal you can get at any trailer supply
Old 07-07-2009, 06:00 PM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
Matt
Check the tongue weight if it around 500 lbs a manual jack is feasable. I'm not sure about heavier.
Old 07-08-2009, 10:24 AM   #10
1987 29' Sovereign
Lumatic, thanks so much. How do I check the tongue weight?
Old 07-08-2009, 11:43 AM   #11
Lumatic's Avatar
1993 34' Excella
Images: 16
According to the specs I have the tongue weight for a 87 29' side bath Sovereign is 700#.
electric jack mrmossyone Batteries, Univolts, Converters & Inverters 5 11-19-2007 02:02 PM
Electric Jack niftypkg Jacks, Stabilizers, Lifting and Leveling 9 02-25-2007 06:09 PM
Electric Jack scf31 Jacks, Stabilizers, Lifting and Leveling 2 06-18-2006 06:16 AM
Electric Jack Dbraw Jacks, Stabilizers, Lifting and Leveling 17 05-22-2006 05:33 PM
Electric Jack Devoman On The Road... 12 09-19-2005 03:59 PM
