Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 03-01-2006, 04:38 PM   #1
Bike Hitch for 1996 21 Ft Sovereign
Can I put a bike hitch on my A/S? Read about "frame separation" on older longer models, so erring on the side of caution seems like a good idea. If the answer is yes, then does anyone have a lightweight design that works? I'm assuming there's nothing I can buy "off the shelf" for this and I don't want to over-engineer a 100# behemoth!! Appreciate any help. Nick
Nicksut is offline   Reply With Quote
Old 03-01-2006, 05:31 PM   #2
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
This is just a thought, I have seen and I'm sure you have to, the bike racks that slide into your reciever hitch, you could have your local welding shop make you a light duty one that you could bolt to your frame and use the reciever bike rack. I do not think that you will have a tail droop issue. Now my model I would not do that to but than again maybe I would, my floor is not rotted out like the the ones that are giving troubles. And my frame is in good shape.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 03-01-2006, 06:07 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
My 31 foot had a Red Ant carrier from previous owner and now has separation problem. I would not do it on any model over 26 foot. I would just balance the bike on the bumper with a couple of retainers and bungy cords over the rims and some light weight stand offs to keep it away from the body and buumgy cords. Lossen and rotate the handlebars if necessary. Keep weight to a minumum or carry the bike inside when you travel. I put ours in trailer or back of the truck.
Old 03-01-2006, 06:19 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
The problem is not so much the length of the trailer but the amount of weight behind the axle, IIRC called lever momentum in physics. Kind of like the fat kid with the skinny kid on the seesaw. Any added weight to the rear bumper is going to cause problems of some type, sooner or later. It just shows up quicker on the longer, older trailers because of where the weight of the tanks and rear bath.
Aaron
WBCCI #XXXX AIR #2495
'85 Sovereign 25' j54mark 1984 - 1989 Sovereign 13 11-07-2013 11:24 AM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
Bike Rack ALANSD Our Community 3 03-19-2002 10:57 AM
