Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 06-10-2006, 08:39 PM   #41
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Originally Posted by 85MH325
The Excursion has some design flaws that contribute to that vague feeling I'm sure you're having. I switched to "E" range tires (my Ex came with "D"s that got recalled) and I replaced the junk stock shocks with some really good Edelbrock gas shocks. The rear axle four leaf spring stack is only half that of the Superduty trucks, and the four spring stack isn't sufficient to keep the axle centered under the Excursion causing rear-axle steering. THAT is a real problem without towing; it's a disaster with a trailer attached. That requires Land Yot radius rods and a Helwig 36mm sway bar to overcome the shortcomings of the design. My Ex now tows the 34' like it's on rails. It used to be white knuckles all the way.
Good luck with yours!
Roger
Just finished the installation of the Helwig rear sway bar and Rancho gas shocks all around. Noticeable difference on the test drive - we'll see how it handles with the trailer in tow and go from there with any additional mods. Thanks for the advice.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 61 07-26-2022 07:20 PM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 32 08-01-2021 11:03 AM
Newbie AS Bambi Owner! KY Girl Our Community 15 02-17-2020 07:47 AM
Which tow vehicle for a 19' Bambi? Jay_Iski Tow Vehicles 50 02-21-2017 07:12 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
