01-13-2014, 12:27 PM
#101
hillsborough
, North Carolina
That makes sense. Your Airstreams are light compared to a truck versus my tractor to my Trailblazer. If it can redistribute as much weight as you need it to, it is clearly the easiest WD system to use.
I wonder if they'll make one with a longer distance ball to chain plate for people who want more redistribution. Heck, they could just extend the tapered insert 2 or 3 inches, tweak the chain plate, and violla...
01-13-2014, 01:12 PM
#102
2012 25' Flying Cloud
Battle Lake
Our ProPride is at least as easy to use than the Andersen we had, just align it, back in and latch it, set the weight distribution, hook up the cables/chains and go. Our Equal-I-Zer was also as easy.
As for longer distance to get more leverage, there was already a problem with the friction material being squished out of our Andersen hitch from the pull on the lower side of the hitch, as well as elongated bracket mounting bolt holes in our trailer A-frame. There was also significant wear on one side of the hitch ball.
Doug and Cheryl
01-13-2014, 02:10 PM
#103
hillsborough
, North Carolina
The Equal-I-Zer is also on my list, but it clearly isn't as easy to hook up as the Andersen. I'd probably just get the E2. I'm just going into town to pick up an implement for my tractor or taking the tractor to the dealer. You guys who drive for hours clearly will have more experience with these hitches than I will. I'll drive the tractor up to the correct location, chain it, hook the trailer to my Chevy, and go. The Andersen seems like it won't slow me down much doing that. The E2 seems like it will take more time, but costs less.
I haven't heard of ProLine, is it in the same price range as the Andersen and the Equal-I-Zer?
01-14-2014, 10:36 AM
#104
hillsborough
, North Carolina
Got it, thanks.
I'm only an Airstream owner's sibling, but contributors here have shared more about their experiences with the Andersen than on any other forum, so I inquired here. I can see both pros and cons to the design. More pros than cons right now given my intended use.
01-14-2014, 10:38 AM
#105
2013 27' FB International
El Dorado Hills
I own both hitches and found the opposite to be true. The Anderson hitch bushing nuts needed to be torqued every time to it was attached, then un-torqued to remove it. It has these two large nuts (they provide a large socket) that squish the rubber bushings to create down force. Simply jacking the trailer up/down with tow vehicle attached was insufficient to loosen/tighten the chains enough, thus additional torquing was needed. I admit that I was trying hard to get the hitch to properly balance my tow vehicle, which it barely did at its maximum setting. Also, maybe a quirk of my hitch, the triangular plate never wanted to just fall off, even when the chains were totally loose. I had to beat on it to remove it.
I think the equalizer hitch is easier to hook up because, once adjusted, the down force is the same every time. Hookup is brainless. Jack the trailer up, slide the two square bars in their slots and place the clips. I spend more time holding the electric jack raise/lower switch than anything.
I'm not bashing the Anderson hitch. It just didn't work well for my application.
01-14-2014, 11:29 AM
#106
hillsborough
, North Carolina
I want to apologize here. I'm stuck trying to compare apples to oranges in asking you guys questions, so the opinions you're all providing me with and the explanations may not translate to many others on this site. Only to those who are considering the Andersen and have both an Airstream and a material carrying type of trailer. What kscherzi said makes sense if your trailer weight is pretty consistent.
My flat trailer will weigh 2800 lbs empty. How much it weighs halfway through trips behind my poor Trailblazer will vary from 2800 to around 5000 lbs, and how much tongue weight I have will depend on how far forward the rental yard drops an implement or on how much material I'm picking up.
Being able to measure the front bumper height and just crank another turn or two on the Anderson bushings to get back some front wheel weight, seems perfect. It's never going to be as exact as you guys can do on a CAT scale, but it's a lot safer than nothing.
I was initially concerned about whether the Andersen would be sufficient to let a larger vehicle tow the actual tractor short distances. In those situations, which will only happen a couple of times a year, the trailer GVW will be around 7600 lbs . I can paint a line on the bed showing where the front wheels go to get 800 lbs on tongue weight, but I'll still have to re-adjust any WD hitch each time I use it. The crank & measure adjustment seems better for me. Hope I'm not missing something thinking that way. It's why I wanted to learn a bit more about the Andersen before committing several hundred dollars to a WD hitch.
01-14-2014, 11:34 AM
#107
2013 25' Flying Cloud
san mateo
The built-in camera of the Tundra did it for me, plunged in and got it as my 1st truck from an SUV user. An Andersen hitch w/ a Quickbite coupler and now a truck w/ a back-up camera make's it the smoothest Airstream ride, I will report on that later. I know though that the Andersen is the only hitch w/ an anti-bounce feature and I can say that it's, true. Hope that this old issue of weight distribution pertinent & needed for the bar-type hitches do not confuse users or perspective Andersen users. An Andersen is unlike anything out there and weight distribution is not mentioned on setting it up. Just do the fender measurements and you're good to go. The older bar type MUST hone in on their scale numbers and worry about WD because of ride roughness, wear & tear issues.The anti bounce feature of the Andersen is unique and must be emulated somehow w/out infringing on patents. Not that the Andersen doesn't transfer weight nor enough weight nor this or that because the Andersen is above all that, nothing to compare it with. The future of trailer hitches is here, it'll get better, the bar-type is too rigid, too expensive, too dirty, too expensive. Hate to bring up an old worn out topic but it keeps popping up?
01-14-2014, 12:13 PM
#108
hillsborough
, North Carolina
I see what you mean, Mike.
Maybe my first trip should be to the Food Lion for some of that Kool-Aid
Still, even realizing it's a new product that could be tweaked or improved over the next few years, if my understanding of how I could adjust it after my trailer is loaded at a rental yard is correct, I suspect it is a decent choice for me right now.
02-02-2014, 11:20 AM
#109
Princeton
, New Jersey
Just an update
We just returned fro a 3,400 mile trip with my Andersen that started on 1 in. of ice, at 25 degrees. While the ice was only a short distance to the open road we then had wet roads to deal with. Again I can state that I have to look in the mirrors frequently to make sure the trailer is back there. Without sway, noise, or porpoising you just have to check once and a while.
Now as for the height of the receiver box and the Andersen's ability to transfer weight.
The height of the box will have little or no effect what so ever an the torque generated by the hitch and the transfer of weight. Yes if that deminsion was changed by feet, and not just a few inches there would be an effect.
There have been comments that the length of the bars effect the torque on the receiver as apposed to the height of the Andersen ball chain relationship. Yes the bars can generate a greater force on the hitch and thus a greater force on the receiver that can not be compared directly to the ball/chain distance of the Andersen.
If they want to compare the systems then credit has to be given to all of the components of each system. All WD hitches attempt to transfer weight by applying a torque force on the receiver. The thing that is new with the Andersen is how it generates the force. The urethane bushings, while they do not act in the same manor as conventional bars, still produce a rotational torque at the receiver and thus move weight forward.
Now to say that 28 in. bars produce more force than the 6 in. separation the Andersen has between the ball and the chain plate is an apples to oranges comparison. A more accurate comparison would be the the comparison between that 6 in. moment arm of the Andersen system and the 4 in. moment arm the trunnions of a Reese system provide. It is that final point of application that governs the systems ability to transfer weight not just how the force was produced.
Now that said one could produce a bar made of an I beam and transfer infinitely more weight than any system relying on urethane bushings. And yes the ride would be like that of a brick. That is the argument presented against the Andersen hitch and yes there are cases, generally lightly sprung rear axle tow vehicles, where that is a valid argument. Years ago Reese demonstrated that they could transfer enough weigh so as the rear tires could be removed from a front wheel drive vehicle. Neat experiment but not what most of us are dealing with.
That need is not the general case with today's majority of tow vehicles. If you are in fact towing with such a vehicle look elsewhere for your hitch system. But if you are towing with a truck and want a superior towing experience you have to stop an Andersen owner and ask some questions.
Please note I am not towing one of the smaller trailers that others have mentioned could not be towed with an Andersen.
2004 Excursion 4x4
02-02-2014, 06:07 PM
#110
2012 27' Flying Cloud
W
, New England
Originally Posted by HowieE
...snip...
...snip...
HowieE - I think your point is that how different systems work can be an apples/oranges comparison. I can agree with that. And, at the end of the day, regardless of how they do it, a WD system should move sufficient weight to the front axle (depending on manufacturer recommendations, that can be 50% to 100% ).
Apologies if I've missed this, but at the scales, how much weight is lifted off your front axle when you connect your trailer; and when you apply Andersen's WD, how much is restored?
Thanks.
02-02-2014, 06:34 PM
#111
Livingston
No, that is not a more accurate comparison -- it is an incorrect comparison which violates laws of physics.
The moment-arm fulcrum for both hitches is the hitch ball. The correct comparison is:
1) the product of the effective WD bar length (approximately 30") multiplied by the total WD lift chain tension (perhaps 2000#), versus
2) the product of the vertical distance from Andersen chain plate to ball center (reported to be 6.25") multiplied by the total Andersen chain tension (perhaps 2000#).
The first example torque would be 60,000 lb-inch versus the second torque of 12,500 lb-inch.
Ron
02-04-2014, 07:30 PM
#112
1987 25' Sovereign
Oregon
, Ohio
Originally Posted by steveirving
Thanks for all the answers and insight guys. Our 24' Tradewind is 4000lbs fully loaded and my Highlander SUV is 4500 lbs. Our tongue weight fully loaded is about 380-400 lbs (light compared to what most of you haul). The big thing, for me, favoring the Andersen over the other style of WD systems is the weight (60 lbs vs 80-90 for other systems) puts me very close to my 500 max tongue. Based on feedback from owners, I have no doubt the Andersen sway control works great. I just wanted more reassurance it will alleviate some of my 400lb tongue weight.
We have a 1987 25 footer that tips the scales at 6000 pounds. Jackson Center told me to multiply that by .15 to get the tongue weight of 900 pounds. I tow with a heavy 3/4 ton F250. The Andersen hitch does a fine job of leveling out the truck when done according to the hitch instructions. I am very happy with this hitch system for weight distribution and sway control.
02-04-2014, 08:19 PM
#113
Princeton
, New Jersey
Ron
Ron
I find it interesting that you offer an mathematical explanation that offers 4 amounts, 2 of which are directly measurable and one that has been documented by actual measurement. The distance between the trunnion sockets on a Reese hitch, approx 4.1/5 in. and the plate to ball distance, approx 6in., of the Andersen can be measure by anyone. The tension in at least one Andersen system was recorded with a strain gauge, 2,000 lbs. and offered in this thread.
http://www.airforums.com/forums/f464...ead-92131.html
My question is what is the bases for the assumption that the lift applied by chains to a set of bars is 2,000 lbs.
2004 Excursion 4x4
02-05-2014, 12:43 PM
#114
Livingston
Howie, the basis for my use of "perhaps 2000#" of combined lift chain tension is both empirical and theoretical.
An example of empirical data is found in "The Hitch Torsion Bar Story" in the form of the WD bar load-deflection plots at the end of the article.
Andy's testing involved testing five different WD bars at loads up to 1600# to 1800#.
A middle-of-the-range load of 1000# per bar produced deflections of 1-1.6" which seemed to be fairly representative of a "typical" WD bar loading.
These data show that four of the five bars could be loaded to 1600-1800# per bar without showing signs of yielding.
The theoretical approach is based on calculating how much WD bar load might be required to restore a load of 500# to the front axle of a truck with 157" WB, towing a trailer which is 240" from ball to mid-point between axles, and using WD bars with effective length of 30".
Physics of levers says the amount of required load transfer to the TT's axles would be about 500*157/(65+240) = 257#.
And, a load transfer of 257# to the TT's axles requires a combined WD bar load of about 257*240/30 = 2056# -- approximately 1000# per bar.
Ron
02-05-2014, 01:52 PM
#115
Princeton
, New Jersey
I accept you explanation of the 2,000lbs. used in your post.
Now if you accept my comment that the Andersen is not appropriate for a lightly sprung TV and that there is a difference between the 6 in. separation between the ball center and the chain plate of the Andersen and the 4 in. separation of the trunnion cups on a Reese. If so most readers will be able to see the limit of the Andersen to transfer weight and decide for themselves if they need that amount of transfer and thus be willing to sacrifice the advantages of the Andersen.
A bar system will overcome the shortcomings of a lightly sprung TV. The Andersen will provide a superior ride quality for those who are towing with the majority of the current TVs.
2004 Excursion 4x4
02-05-2014, 05:00 PM
#116
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
Ron
RIVETING!!! (pun intended)
(sorry, i couldn't resist)
(thanks for working thru this issue w/ "level heads", and edgumicating us common folk)
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
02-05-2014, 06:54 PM
#117
Livingston
Now if you accept my comment that the Andersen is not appropriate for a lightly sprung TV and that there is a difference between the 6 in. separation between the ball center and the chain plate of the Andersen and the 4 in. separation of the trunnion cups on a Reese.---
Howie, you asked for the basis of my assumptions, and I provided same.
Now I ask you -- what is the basis for your assumption that the Andersen is not appropriate for a lightly sprung TV?
I've seen only two reports of people being able to achieve close to 100% front axle load restoration when using the Andersen WDH.
One TV was a Honda Pilot, and the other was a Toyota FJ Cruiser.
It seems both of these TVs would be considered to be "lightly sprung", and they both achieved close to 100% FALR.
Why do you say the Andersen WDH is not appropriate for such vehicles?
A bar system will overcome the shortcomings of a lightly sprung TV.---
Exactly what are the "shortcomings" of a lightly sprung TV,
and how does a bar system overcome them?
Ron
02-05-2014, 08:06 PM
#118
Common Sense
Ron
Ron, As you know, the FJ Cruiser is mine, and yes the Andersen hitch does distribute 100% axle load restoration , or more with my trailer. It is my opinion the Andersen works well for me because a:the Casita's tongue weight is only 400 pounds, +,-, and b:the FJ Cruiser is a rather short wheelbase vehicle with an even shorter rear overhang.
The FJ for it's size and type vehicle is actually not very "lightly sprung", and is rather stiff with parallel leaf springs. It is easily as stiff suspension as a mid sized pickup truck.
Regards,
Steve
02-06-2014, 12:09 PM
#119
Livingston
Steve, I concluded your FJ would qualify as "lightly sprung" (as regards load transfer) because of how easy it was for you to get the front end to drop below its non-hitched height.
Ron
This trailer is about 3,500 pounds, and 400 pounds tongue weight. The adjustment for the proper weight distribution went suprisingly easy, and I was rather taken by the light amount of tention required on the chains to return the front of the vehicle to it's non hitched height. As a matter of fact, I adjusted it too tight on initial attempt, and had to back off to raise the front back up a bit.
02-06-2014, 01:04 PM
#120
Mantua
, Ohio
A mid sized pickup would be a three quarter ton. Your FJ is that stiff? Jim
