02-05-2013, 08:06 AM
Colonial Airstream NJ
1961 16' Bambi
1997 19' "B" Van Airstream 190
Millstone Township
, New Jersey
WARNING!! New 2013 Ram Truck - Brake Controller, Aftermarket
From Cequent Performance Products
TECHNICAL BULLETIN: TB13-01
Issue Date: 02/01/13
Installing Electric Brake Controls – 2013 Ram Trucks
Vehicles - 2013 Ram Truck - All
Product Family - Brake Controls -All
The electrical system on the 2013 Ram trucks has changed. Though the brake control connector is the same as the 2010-2012, the wire functions have changed. The terminal that used to be the stop light signal, now has battery voltage, whenever the ignition is in the run position. According to Dodge, it is not possible to install an aftermarket electric trailer brake control into these trucks. Dodge says, that “the 2013 Ram has “Powernet” and utilizes multiplex wiring that is different from any previous design’s, therefore, your aftermarket trailer brake control is not compatible”
At this time, the only aftermarket brake control that can be used on a 2013 Ram truck, is the Tekonsha 90250 Prodigy RF. As soon as more information is available, a revision to this technical bulletin will sent out.
WARNING!!! - Any attempt to install an aftermarket brake control into the vehicle, may cause severe damage to the vehicle’s electrical system or electrical component!
Patrick Botticelli - Colonial Airstream 595 State Hwy 33 Millstone Township, NJ 08535 - 1-800-265-9019 www.colonialairstream.com
02-05-2013, 08:14 AM
Ottawa
, ON
Wow, this is a very important message Patrick, thanks very much for posting it!
It's a very strange move on Chrysler's part, isn't it? Just when there is more "buzz" around their trucks, they complicate the issue of adding a trailer brake controller.
Why, I wonder?
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
02-05-2013, 08:51 AM
1972 31' Sovereign
Lexington
Because they sell an integrated brake controller as part of the towing package...
02-05-2013, 08:58 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Very scary if not known in advance; thanks for the info.
02-06-2013, 07:11 AM
2003 25' Safari
Riverside
Something to consider on new model vehicles...........just about everything on the new model Rams are on the network,just like any computer network there is communication between them to allow full functionality.The power net allows many more modules to be on the net and is designed for easier dignostics when the net crashes.The network can not have added or removed modules with out reprogramming at the corporate level
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
02-13-2013, 11:15 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Probably around 2005 or 2006, BMW motorcycles came up with the "can bus" and it make it virtually impossible to wire third party accessories into the "smart" wiring harness. They used square wave amplitude to carry intelligence. If one did not have access to the dealer only black box, then it was russian roulette with an automatic to play with adding or deleting even BMW accessories let alone third party stuff.
There is a lot of conversation in the Dodge forums concerning the current built-in brake controller's compatibility with various brands of trailers and brake systems. There have been attempts to swap the innards of one brand or another of brake controllers into the space behind the dash and use the conveniently located Dodge control head. As they say, "How's that workin' for ya? Not so good."
There has not been a totally smooth programing experience with the 2012 Dodge vehicle computer systems and the trailer brake system. My Ace up my sleeve is the the Prodigy RF model was how I worked the brakes from the Mercedes, so it is already on my trailer if the Dodge factory system does not work properly. This may be the preferred solution for the 2013 Dodge models as well.
YMMV
02-22-2013, 12:12 PM
2020 30' Classic
Derwood
, Maryland
Porsche and VW have used CAN bus for years now - I have workarounds that might now be relevant on the new Ram's....
In particular, check out my setup for the Brake Controller installs on either my 2005 Cayenne S or the 2010 Touareg TDI.....
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
02-23-2013, 05:48 AM
2003 25' Safari
Riverside
It's not just the Can bus that is the issue,removing the integral brake controller will trip a ck engine light-due to missing module on the bus.
Adding an external controller not removing the oe would work if done correctly but why bother? The 0em controller has been refined enough to keep 90% of drivers happy
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
02-23-2013, 07:12 AM
Common Sense
I recently traded an '08 GMC 3/4 ton for a '12 Ram 3/4 ton which has the factory brake controller.
While it does the job, the Ram controller is not anywhere near as smooth as the GMC was with the same trailer.
Regards,
Steve
02-23-2013, 07:50 AM
Small Town
AS a PS, the brake controller in our 2012 Ram worked great with both our 2012 as well as 2013 Airstreams.
02-23-2013, 09:25 AM
2006 31' Classic
Archer
We have the 2010 Dodge Ram 2500 Laramie that came with integrated brake controller-BUT it wouldn't work with Electric over Hydraulic Brakes on our 2006 Classic 31. We had to get a plug and play wiring harness for a P3 that plugged right in to the wiring, but also had to get Dodge to de-program the integrated Brake controller from the EVIC so it wouldn't keep looking for it and throw error messages. Before the local dealer could do that, they had to apply for permission from Dodge to do it so it wasn't as easy as one would think- probably a liability issue. The P3 seems to be doing the job just fine, but really wish that we could have used the nicely mounted integrated one from Dodge- we weren't willing to exchange our Classic for one with electric brakes, though, as we are still in love with our AS :-)
02-24-2013, 08:45 AM
2003 25' Safari
Riverside
Yes, the way it works is they have to remove the option from the corporate data base (Done at the corporate level)Then your truck is reprogramed with the new option list.This procedure is done in a reverse fashion when you add any option.
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
03-08-2013, 04:44 PM
Denton
, North Carolina
new plug
Cequent/ Bargman has come up with a wiring harness for this problem.
http://www.hitchpro.com/application/...G1130_revB.pdf
I don't plan on carrying it but can get it drop shipped if anyone needs it.
Solution one does not look to bad.
Solution two on the above PDF is very pricey. It looks to be a good product that they have put a lot into.
Dan Brown Denton NC
03-08-2013, 06:09 PM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
The brochure refers to RAM 1500 trucks. The original post refers to ALL Ram trucks.
This brings up the question of whether the 2500/3500 series uses the same bus set up?
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
03-08-2013, 06:47 PM
2014 31' Classic
Apache Junction
I used the the Prodigy RF unit with my early 2007 Mercedes as it was the only option without taking the interior out of my specific vehicle. After setup, it worked very well.
The 2012 Dodge Ram 2500 built-in controller works fine for me with our 25FB. I kept the Prodigy RF just in case an issue develops with the Dodge controller or I need to use a different TV on some occasion.
05-13-2013, 09:19 PM
2020 30' Classic
Derwood
, Maryland
I do agree - the OEM controller on the 2013 2500 is Great - both electric and hydraulic over electric.
**I Love U.S.A.**
05-31-2013, 05:36 AM
2007 23' Safari SE
Central
, Connecticut
Another solution: From what I've been told, you can add the integrated Ram controller after the fact through Mopar accessories - about $250.
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
11-17-2013, 06:46 AM
2001 34' Limited
Tucson
Question......
I pick up my new 2013 Ram 2500 Power Wagon on Monday. Is there something I should know about the oem brake controller? Why would anyone NOT use it? Or why would someone consider putting in an aftermarket unit if the oem controller was already there? Just curious....
Today I was going to pull out the Prodigy from my Suburban trade-in to keep on hand as a back up unit. Good to know now that I cannot use it on the Dodge
11-17-2013, 06:57 AM
1961 24' Tradewind
1969 29' Ambassador
Jamestown
, Tennessee
I have a 2013 with the OEM brake controller..
It is the smoothest controller I have ever used in over 40 years of trailering. Even better than the Jordan that i thought was about as good as it gets. (never used the prodigy)
From reading various forums i get the impression that the earlier OEM controllers had some problems
So far I couldn't be happier with the 2013 controller
13 Ram 2500 TD
