Old 10-20-2019, 02:42 PM   #21
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Go for it. It's only a 20' Argosy. Just make sure your trailer brakes work, and your hubs are lubed.
Seriously people?
Cheers
Sidekick Tony
Old 10-20-2019, 03:05 PM   #22
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Land Of Enchantment , New Mexico
Seriously people?
Cheers
Sidekick Tony
Hubs are lubed and ready to go...
Name:	hold my beer.jpg
Jaxon
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 10-20-2019, 09:29 PM   #23
2019 25' Flying Cloud
lancaster , California
Originally Posted by Jaxon View Post
.......It's a quandry when you have to be somewhere and that's all you got. I would look reall hard at other options/solutions and not take the risk because that's what it is - a risk. You might make it but at what expense?......
while there's a lot of good advice here, IMO, this is one of the wisest things said. seriously consider that question.
Aluminaut is offline   Reply With Quote
Old 10-21-2019, 11:32 AM   #24
1976 Argosy 20
Doylestown , Pennsylvania
Thank you for all the great information and advice. I will make sure my TV is properly equipped and will look into other options for the time being.
I will not have the jeep nor the trailer packed to the max. Part of the reason I am taking this route is to shed all the unnecessary **** I have accumulated over the years and only take with me what I need. I will be taking the trip slow and have no specific date that I will make it to CA. When i find places I vibe with, I will stay there until it's time to go and check out the next spot.
Gear ratio is 3.73. Tires/rims are after market, M/T, stock size, no lift. Jeep has 16k miles on it. Has a Class II reciever, trailer Tow w/4-Pin Connector Wiring which I will have to replace
npm5031 is offline   Reply With Quote
Old 10-22-2019, 03:35 AM   #25
1966 26' Overlander
Mt Holly , NC
This is you right here, 2015 JKUR towing 20ft 66 GT (3000lbs) Equilizer hitch was not adjusted in this pic but you get the idea. The D44 rear end you have was previously rated to pull 5000 lbs on an XJ or MJ, all the searching I did suggested your weak point may be cooling. Pulling that on flat land the computer showed the Jeep getting 14 mpg and it only gets about about 15.5 around town normally, indicating it's not stressing the vehicle. Make sure you have an equalizer and the trailer brakes are hooked up and working, the Rocky Mtns are a different animal than anything we have on the East Coast. Enjoy the ride.
specauto1 is offline   Reply With Quote
Old 10-23-2019, 09:00 AM   #26
1976 Argosy 20
What equalizer did you use? Trailer brakes are working. My brother towed it home with his excursion no problem. I have a brake controller coming in the week for my Jeep.
Old 10-24-2019, 02:09 AM   #27
1966 26' Overlander
Mt Holly , NC
Equalizer Hitch
That's just a generic one you can order anywhere. It came from Redneck Trailer Supply (yes, that's the correct name, and it a big business). I have an original Airstream equalizer hitch that came with my 66 Overlander, but I'm not that fond of that one. The hitch and the trailer brakes are the key to pulling this off for you. Get the rig as level as possible. If you weren't going across the Rockies I wouldn't give it a second thought. I'd plan my trip with the least grades possible.
Old 10-24-2019, 02:07 PM   #28
Central , Mississippi
2018 JKU with my ‘61 Overlander I just hooked up. The trailer is light and minimal WD on the bars brought the front end back to unloaded height, the back is 3/4” below unloaded height. I still plan on shortening the shank 3” and reinforcing the hitch for more weight transfer. If it tows ok I will re-gear to 3.73 or 4.11
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 10-24-2019, 03:17 PM   #29
AdvToaster's Avatar
2020 30' International
Whereweparkit , Anywhere
Originally Posted by Richard Pope View Post
I believe by now if you have read the comments you have received, you get the gist that the answer is NO. You not only endanger yourselves but others who share the roads with you. That Jeep is equipped to pull 3500 pounds.
My first trailer was a new 24 foot Argosy and I pulled it with a 78 Jeep Cherokee Chief with a 390 engine. Big tires, brakes, etc. It was wonderful. I pulled my Argosy around the USA for several months without a problem but it was built for that weight.
I'd either sell the trailer, ship it, store it, have someone else tow it, but not tow it with your Jeep.
I'm not commenting on the ability (or inability) of a Jeep JL Unlimited to safely (or legally) tow the OPs specific trailer, but If you're just talking specs the JLU is far better suited than your old 78 Cherokee Chief. The JLU has nearly 100 more HP, a 10" longer wheelbase, weighs almost exactly the same, and has 12.9" front and 13.4" rear disc brakes, compared to the 11" front rotors and 10" rear drums on your SJ. The times have changed.
Jeremy
Full-timing it in a 2020 International Serenity 30RB!
https://AdventureToaster.com
TV: 2020 Ram 2500 Limited CCSB Hemi
AdvToaster is offline   Reply With Quote
Old 10-24-2019, 03:40 PM   #30
1977 Argosy 22
Fort Collins , Colorado
The Argosy 20 was designed to be towed by a small car.
Argosy.123 is offline   Reply With Quote
New 2015 16' Sport, towed by Jeep Wrangler Unlimited jt1911man 2005 and newer - Bambi all models 28 05-05-2015 05:53 AM
Jeep Wrangler Unlimited as Tow Vehicle? AmrcnDrifter Tow Vehicles 46 03-27-2015 08:40 PM
2008 Jeep Wrangler Sahara <-> 1973 Airstream 25' Trade Wind Land Yacht GVWR: 5800Lbs. sysgenss Tow Vehicles 12 08-07-2009 09:00 PM
