02-25-2016, 07:00 PM
#141
1999 34' Excella
Cinnaminson
, New Jersey
Curious, what were your actual weights compared to mfg listed curb weights?
02-25-2016, 07:47 PM
#142
Oswego
Curb weight = 5409 (includes 150 pound driver
Scaled weight after installing spray in bed liner. Stainless assist steps, mud flaps, and soft tonneau = 5720 pounds. I weigh 180 so accessories weigh 281 pounds.
Edit: there were a few other items included in that 281. A road emergency kit, air compressor, and thule roof rack feet and bars.
-Rich-
02-25-2016, 08:56 PM
#143
2013 27' FB Classic
Clermont
I've got mine!
Nissan Titan XD SL
Towing capacity: 11,638.2 lb.
Max Tongue weight 1,163.8 lb.
Max payload: 1,588 lb
I've been towing our 2013 27 Classic with a 2006 Dodge Durango -- it had a towing capacity of 8950 lb. and a payload of 1600 lb.
Our previous trailer was a 2007 Safari and the Durango did the trick, but struggled a bit with the 27 Classic. The Durango with its 5.7 Hemi gave us 88,000 mostly trouble free miles with the exception of a couple of computer problems, with the last issue being an intermittent dead electronics, wouldn't start.
Looking forward to the new Nissan -- drove a bunch of trucks, the XD is a perfect fit for us.
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
02-26-2016, 07:41 AM
#144
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
02-26-2016, 08:15 AM
#145
Oswego
Originally Posted by switz
No kidding! I had heard several years ago that the standard was going to change to 175....but it never happened. Even that is probably below the average today.
-Rich-
02-26-2016, 08:16 AM
#146
Oswego
Originally Posted by tkowalyk
I've got mine!
Nissan Titan XD SL
Do you have GVWR and Curb weight?
-Rich-
02-26-2016, 11:27 AM
#147
1994 30' Excella
alexandria
, Kentucky
200 lbs is much more likely the average as I look around the world I live in. I'm tipping the scale at 220..... would like to get back to 200.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
02-26-2016, 01:17 PM
#148
2013 27' FB Classic
Clermont
Curb weight is 7,402 lb. (heavy) and the the GVWR is 8,990 lb.
Tom & Lori
02-26-2016, 04:49 PM
#149
1999 34' Excella
Cinnaminson
, New Jersey
Having a heavy truck isn't always a bad thing. All that mass up front on the TV can help control the trailer. Ever try towing 10,000 with a 5,000 lb truck? the trailer tends to have more of that control than the tow vehicle which is never a good thing. It would be nice to see the curb weights a little lower though.
Any idea what the GCWR is? probably in the owners manual...
02-26-2016, 05:18 PM
#150
2012 25' Flying Cloud
Battle Lake
Originally Posted by excellaf350
Having a heavy truck isn't always a bad thing. All that mass up front on the TV can help control the trailer. Ever try towing 10,000 with a 5,000 lb truck? the trailer tends to have more of that control than the tow vehicle which is never a good thing. . .
Not true. It is the stability of the truck that controls the trailer, and that is where to put your money. It is excess truck weight that can be hard to control when things go wrong.
There's a lot more to the answer but too far off topic.
Doug and Cheryl
02-26-2016, 05:23 PM
#151
Oswego
Originally Posted by dkottum
not true. It is the stability of the truck that controls the trailer, and that is where to put your money. It is excess truck weight that can be hard to control when things go wrong.
x2^
-Rich-
02-26-2016, 05:38 PM
#152
N/A
, N/A
Everything else being equal, the extra weight of the TV (relative to the trailer) helps with overall stability. In another thread, someone posted a technical publication with this conclusion.
02-26-2016, 06:30 PM
#153
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
https://simple.wikipedia.org/wiki/Co...nt_of_friction
When this is overcome, loss of control is more likely to happen.
Lance
02-27-2016, 08:23 AM
#154
1999 34' Excella
Cinnaminson
, New Jersey
I'm just saying having a larger (HEAVIER) truck isn't gonna hurt. Sure there are a lot of other things to consider. But in more of a general terms, I would rather have a 10,000 lb TV than a 5,000 lb TV with a big heavy trailer... that's all.
the Titan does seem heavy at 7000+lbs, but its got a lot to offer. Larger fully boxed frame, bigger brakes ect... all that stuff adds weight. Its certainly heavier than an F150 or a chevy 1500, but its to be expected I think, since they are claiming/marketing it as beefier truck.
02-27-2016, 08:41 AM
#155
2000 25' Safari
Davidson County
, NC Highlands County, FL
I saw this same data on Nissan's website. It did not match the vehicle I saw on the dealer's lot. In this chart the Platinum Reserve's 4x2 payload is listed at 1,676 lbs. The one that I saw was 1,444 lbs on the door sticker. It's another example of advertising not matching reality.
Here are some hard fact numbers I found
Max tow ratings:
S: 4x2 will have a max-tow rating of 12,314 pounds; 4x4,12,038 pounds
SV: 4x2, 12, 164 pounds; 4x4, 11,888 pounds
PRO-4X: 11,784 pounds (only offered in 4x4)
SL: 4x2, 11,915 pounds; 4x4, 11,638 pounds
Platinum Reserve: 4x2, 11,836, 4x4, 10,608 pounds
GVWR:
All 4x2 S, SV and SL trims: 8,800 pounds
All 4x4 S, SV and SL trims: 8,990 pounds
The PRO-4X (4x4 only): 8,990 pounds
Platinum Reserve Titan: 4x2, 8,880 pounds; 4x4, 8,950 pounds
Curb weight:
S: 4x2, 6,709 pounds; 4x4, 6,986 pounds
SV: 4x2, 6,876 pounds; 4x4, 7,152 pounds
PRO-4X: 4x4 only, 7,257 pounds
SL: 4x2, 7,126 pounds; 4x4, 7,402 pounds
Platinum Reserve: 4x2, 7,204 pounds; 4x4, 7,480 pounds
Payload:
S: 4x2, 2,091 pounds; 4x4, 2,004 pounds
SV: 4x2, 1,924 pounds; 4x4, 1,838 pounds
PRO-4X: 4x4 only, 1,733 pounds
SL: 4x2, 1,674 pounds; 4x4, 1,588 pounds
Platinum Reserve: 4x2, 1,676 pounds; 4x4, 1,470 pounds
02-27-2016, 09:45 AM
#156
N/A
, N/A
To be fair to Nissan, all automakers do that: publish the maximum payload, which is only available for a vehicle with no options/accessories. Published payloads are useless as they are always more than the door sticker number, which matters. Our GL has a published payload of around 1450#, however, the door sticker says 1150#. I weighed the vehicle on a CAT scale and by subtracting the measured curb weight from GVWR got 1200# - within 50# of the door sticker, which is accurate enough.
