Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 04-28-2016, 09:58 AM   #1
JJA
Missoula , Montana
Main door threshold?
I'm getting ready to install flooring over an entirely new 5/8" plywood subfloor. I'm close to making a decision on the flooring product (probably marmoleum but luxury vinyl is another alternative) and need to find a good exterior door threshold. Any great suggestions that hold down the wood and protect the edge of the plywood in this relatively exposed area?
Also, a couple folks have told me that some of the flooring adhesives turn brittle, crunchy, & fail when exposed to freezing temps. If you have recommendations on the best adhesive for trailers, that would also be appreciated.
Thanks in advance
67streamline.blogspot.com
JJA is offline   Reply With Quote
Old 04-28-2016, 10:48 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Lowe's has many different threshold pieces. Check them out and see what works for you.
MICHAEL
Old 04-29-2016, 02:18 PM   #3
JJA
Missoula , Montana
Adding a picture
My written description isn't very clear - so here is a drawing. Basically, I've seen an exterior main door threshold solution that I like and would love to get as close to it as possible. Attached is a drawing. The one I've seen uses has a smooth ramp that facilitates sweeping small bits of dirt out the main door, caps the end of the sub-floor, and has a little drip gasket.
Old 11-11-2017, 07:00 PM   #4
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
JJA, did you ever find your threshold? I'd love to find one similar to your drawing - ideally out of extruded aluminum with countersunk screws, but beggars can't be choosers.
bredlo is offline   Reply With Quote
Door threshold screw source? Foureagles General Repair Forum 2 10-10-2014 06:44 AM
Screen door/main door sticking together wheelygoode Land Yacht/Legacy Motorhomes 8 06-25-2014 08:03 AM
"Soft"entry threshold. Loeber Repairing/Replacing Floor &/or Frame 5 11-24-2012 03:49 PM
threshold light 1992 sovereign dikku@mac.com Lights - Interior & Exterior 3 04-03-2006 05:49 PM
Rust at threshold of door bdogz Exterior Restoration Forum 4 08-28-2005 06:32 AM
