Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 07-11-2017, 10:27 AM   #1
2004 25' Safari
Shelby , North Carolina
Classic floor
Just purchased an 07 Classic 27 and the rear floor under the table is soft. I am assuming we have a leak and the subfloor is rotten. Any ideas on where the leak might be from and ideas on subfloor replacement...
Help.
tbstill is offline   Reply With Quote
Old 08-20-2017, 06:01 PM   #2
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
windows, seams, etc.. I used captn tolleys creeping crack cure.
its a thin white liquid I use around the windows to seal.. it take a bit to learn how to use it and you need LOT of towels to catch the flow when you put too much on a crack.. only clip a small bit of the tip so there is a small opening works best.
it seems to work great thus far.. also check skylights.. a know place to leak.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 08-20-2017, 06:18 PM   #3
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Sorry to hear about your floor. From what I have read, people find the "dinette" leaks usually due to the pano window seams and, if the dinette is in the rear, the top of the bumper (I call it the bumper tray) where it meets the body of the trailer (lack of seal).
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
Floor Problems - Water under wood floor Ramblinboy Repairing/Replacing Floor &/or Frame 2 05-19-2012 09:58 AM
Floor Newbie - Tile floor DanielB Floor Finishes 15 06-15-2011 07:14 PM
What to do - Above floor Tank or Below floor tank ??? fatwgn Sinks, Showers & Toilets 8 09-06-2009 02:50 PM
Ridge in the floor, '04 Classic Ed Keyes 2001 - 2005 Classic 2 12-08-2004 07:03 PM
