Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 12-09-2017, 10:57 AM   #1
worried...happy...wo...ha
Knuff's Avatar
2015 25' FB International
Menlo Park , California
2015 International - floor question
Hi all, I need to install a flat base holder for my new fuel cell (a different threat and different topic) under the bed.
For this, the base plate simply needs to be screwed into the floor.
I am planning to use 1/2 inch long #5 self drilling metal? or wood screws, "forced" into slightly smaller (in diameter) pre-drilled pilot holes. Any advice on whether this is an appropriate route?
This boils down to the question what is underneath the vinyl fake wood that is standard in the newer airstreams? Simply a metal sheet or plywood? How thick? and does it matter if the screws stick out on the other side? Presumably this will be inside the "under-pan" compartment... Sorry if this questions sounds naive but our trailer is in storage right now and I am planning to do the installation at the start of our next trip.
Edit: 5mm, not #5 => 10 x ½ screws is probably the type I will be looking for. Or longer?
Thanks!
Knuff is offline   Reply With Quote
Old 12-09-2017, 11:19 AM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Wood screws. You are fastening to plywood underneath the vinyl. It’s 5/8” from the factory on late model trailers.
https://www.airstream.com/why-airstream/design/process/
wulfraat is offline   Reply With Quote
Old 12-09-2017, 12:00 PM   #3
Knuff's Avatar
Perfect!
Thanks for the info and link.
Old 12-09-2017, 03:14 PM   #4
Knuff's Avatar
Just to conclude this - Picked up #10 x ¾ wood screws. ⅝ plywood is ½ thick, the ¾ screws are just a little over ½ but the plastic base adds just a little more. This should work.
Old 12-09-2017, 04:54 PM   #5
wulfraat's Avatar
Sweet. Happy days!
Old 12-09-2017, 05:16 PM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
We had the stock flooring in our 201`5 23D International Serenity. The dinette leg wore a hole in it in just 2,000 miles coming back from the selling dealership.
When replacing the stock flooring with Marmoleum, I noticed the stock flooring was so thin it had just one side to it.
switz is offline   Reply With Quote
Old 12-10-2017, 10:02 AM   #7
2015 19' International
Beaverton , Oregon
Wow! That is thin!
pgeller is offline   Reply With Quote
NorCal : 2015 Jackson Rancheria Fally Rally October 9-11, 2015 Coastalview Forum Rallies & Meet Ups 48 05-30-2017 01:49 PM
2015 International 30 vs 2015 Classic ZBoater 2011 - 2015 International 41 05-28-2015 08:47 AM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2006 28' international floor question yogijames Repairing/Replacing Floor &/or Frame 0 05-05-2014 01:59 PM
