Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 03-03-2018, 01:03 PM   #1
1962 22' Safari
Richmond , BRITISH COLUMBIA
How to remove finish on fiberglass end cap?
We have a '62 22' Safari, and we are keeping the end caps with our renovation. We need to remove them to re-insulate and install new wiring. Before we remove them, we would like to remove the textured popcorn like finish off of them while they were still in place. We already tried sanding it, but the finish is super hard. We want to paint them as a smooth finish. We are just starting our renovation project. Does anyone have any tips on how to remove it?
Addiy 62 is offline   Reply With Quote
Old 03-03-2018, 05:13 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Post a pic so we can see what your talking about. Is the texture added on?
Matt
rugjenkins is offline   Reply With Quote
Old 03-03-2018, 07:20 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Welcome to Air Forums Addiy: I think you will find a lot of information here related to your 62 Safari project.
My former 66 Trade Wind had a fiberglass end cap in the bath. It was finished smooth. I'm surprised to learn of a rough finish on the fiberglass in 62. Others will chime in and help explain. Yes, a photo well help.
Fiberglass is laid up in a mold. It would be hard to create a "popcorn" bumpy surface with this process. Usually the mold side of the fiberglass part is quite smooth, like a boat hull. Sometimes the resin is colored giving a molded in color finish. I believe my Trade Wind was made this way.
Let's see how knows more about this trailer than I do.
David
Name:	1309 Bath Sink (Small).JPG
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 03-03-2018, 07:23 PM   #4
2001 30' Classic S/O
Leander , Texas
What grit sandpaper paper did you use? Did you use a sanding block? Orbital sander? Get through top coat?
Sanding is not necessarily easy. If the area changes color, stop and assess the moment.
Picture would help.
John
TexAirS is offline   Reply With Quote
Old 03-10-2018, 10:54 PM   #5
1962 22' Safari
i don't know if the inside finish of the trailer is original or not. i will put a picture soon. the whole trailer is finish with that very sharp pointed popcorn. orbital sander was used with 50 grade paper. in one foot square of sanding and one sand disk was gone and the surface was more smooth but still bumpy. thank you guys for your help..
Old 03-18-2018, 05:21 PM   #6
1962 22' Safari
pictures of my texture
texture is breaking out
ID:	306603   Click image for larger version
Old 03-18-2018, 05:33 PM   #7
1962 22' Safari
more pictures
do somebody have a texture like that
ID:	306607   Click image for larger version
Old 03-18-2018, 07:16 PM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I have never seen anything like that in an Airstream. David
Old 03-18-2018, 09:39 PM   #9
rugjenkins's Avatar
1975 Argosy 28
No that is not original from factor. Someone add that texture. If you look where your cabinets use to be and the smooth strip on the bottom of your endcap that is original. I would use paint stripper to remove. If your not taking the interior skins out, lay some plastic sheeting on the floor and spray or paint on.
Matt
Fiberglass end cap repair Chatooga11 Interior Restoration Forum 6 09-21-2016 03:17 AM
Bathroom and fiberglass end cap RoomRarities Airstream Classifieds 0 08-10-2016 08:49 AM
Fiberglass End Cap - 1965 Airstream Sovereign KimBo Airstream Classifieds 0 05-17-2015 09:44 PM
Bathroom Fiberglass End Cap and Shower Question mello mike General Interior Topics 4 03-25-2010 04:29 PM
Fiberglass End Cap The Flintstones General Repair Forum 13 07-10-2007 03:02 PM
