Old 03-14-2018, 05:19 PM   #1
2007 27' Classic FB
Ridgefield , Washington
Images: 11
Need to get behind wall
I need to get behind the wall in the bedroom of our 27FB Classic to thread a cable from a wall control to the vent fan. I cant figure out how to pull the wall away so i acn make the turn from the ceiling then down bwhind the wall. The wall is 3/8 inch plywood. Thought this may be a little time consuming but not too difficult. Ive removed the TV and all screws that seem to be holding it in place
Whats the secret? Im really scratching my head on this one.
John
Woosch is offline   Reply With Quote
Old 03-15-2018, 11:10 PM   #2
Journeyman
2016 25' International
Deerfield , Massachusetts
I don't know the specifics of your trailer, but most of ours are built with the interior "walls" having been built essentially as furniture in a workshop OUTSIDE the trailer. As such, its likely that the screws holding the "wall" are on the inside.
Instead, look for whatever is holding that big piece of "furniture" against the wall of the trailer. Find those screws and undo them and the whole thing should be able to move.
Alternatively, you could use an osscillating tool (like a Fein Multimaster) to cut along the seams to pull out just the piece you want; this is messier and will mar edges and finishes, but sometimes it saves the need to do a larger scale removal ...
thiel is offline   Reply With Quote
Old 03-15-2018, 11:34 PM   #3
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
What about fishing a line through there? Any chance that would work?
Old 03-18-2018, 10:44 AM   #4
2007 27' Classic FB
Images: 11
Update. It appears that the carpet was the biggest problem. So pulled up the carpet and the right side as you face the wall was coming out but valance was in the way. Took that down. Then the wall bumped into the mounting for the curtains. I couldn't pull it straight back because the left side is in a "U" type of channel.
I hated to give up but, I did. Maybe on the next trip to dealer I can get it done.
John
What's Behind this Fabric Wall Covering? Chasmorgan 1999 Safari 34 05-08-2016 11:20 AM
I have put a TV on the wall behind the bench seat and table I need to get the antenna Trident Land Yacht/Legacy Motorhomes 34 09-07-2015 08:47 AM
Divider wall behind bed and shelf Bikerbill Sprinter and B-van Forum 7 08-10-2014 09:04 PM
Replacing luan in wall behind RS and CS seats hnbrittingha Land Yacht/Legacy Motorhomes 9 01-19-2014 07:24 AM
Help on leaking pipe behind the wall. jock Barker Sinks, Showers & Toilets 1 11-08-2013 05:09 PM
