Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 06-25-2015, 06:03 AM   #1
2013 23' International
madison , Wisconsin
broken folding door - can this be fixed?
The leading edge of our Irving folding door in our Serenity has come out of the track. The photo show that the plastic tab has broken and won’t stay in the track. I can’t fine any replacement parts on the web. Current plan A: get a suitable plastic washer, cut a slit in it, slip it over the tab and try to cram into the track. I hope someone has a better idea. Thanks.
Name:	RV folding door.jpg
jim1949 is offline   Reply With Quote
Old 06-25-2015, 06:49 AM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
New one under warranty??
Old 06-25-2015, 10:25 AM   #3
Johnco's Avatar
2006 19' Safari
Irvine , California
Had the same issue. I contacted the company and they sent me a new tab. I just drilled out the old one, can't remember if I riveted or bolted in the replacement. I seem to recall a clearance issue because I didn't want to remove the track bar.
Johnco is offline   Reply With Quote
Old 06-25-2015, 11:13 AM   #4
2010 27' FB International
La Crescent , Minnesota
Same problem. Irving was very helpful!
3/16 pop rivet-- took the track loose to gain acess to one end.
Jay
mjayjensen is offline   Reply With Quote
Old 06-26-2015, 05:58 PM   #5
madison , Wisconsin
thanks. I'll call Irving and get a new part.
Old 06-26-2015, 06:10 PM   #6
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Me too, have looked for new tabs, cant find them.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 06-26-2015, 09:41 PM   #7
jackson center , Ohio
They should be available through an Airstream Dealer. Call airstream parts at 937 5966111 ext 7428
Schu is offline   Reply With Quote
Old 06-26-2015, 11:27 PM   #8
2005 19' Safari
GLENDALE , AZ
Quick fix (also lasts longer):
  • Remove brass eyelet.
  • Loosely install small zip-tie through hole where eyelet was removed.
  • Loosely install larger zip-tie through small zip-tie and over rail.
  • Tighten both zip-ties slightly while leaving enough slack to allow room divider to slide easily.
Obviously, this doesn't look as nice as the original parts. However, it's quick and easy; and it will last longer than the replacement parts many have difficulty obtaining.
Old 06-27-2015, 01:14 AM   #9
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Call the manufacturer. They sent me a handful without charge via USPS when I explained the problem.
SeeMore is offline   Reply With Quote
« Beds | Top | Header repair »
Can it be fixed? Toilet in 66 Safari drowe42 Sinks, Showers & Toilets 1 07-05-2010 07:55 AM
Loose ball joints - can it be fixed fast? redstart Tow Vehicles 15 09-18-2009 07:19 AM
fixed broken oven handle Isadora Stoves, Ovens & Microwaves 10 04-13-2008 07:28 PM
Can she be fixed? Pinhead Exterior Restoration Forum 10 12-01-2005 10:25 PM
Pocket Door vs. Accordion (folding) Door A/S Interior pap Cabinets, Counter Tops & Furnishings 12 03-10-2005 04:40 PM
