Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 06-17-2011, 09:19 PM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Black adhesive behind insulation.
Anyone know what the black adhesive behind the insulation is?
It seems to melt with paint stripper.
I would like to remove it, is there an easier way.. anyone done this?
Darkspeed is offline   Reply With Quote
Old 06-17-2011, 10:18 PM   #2
Wabbiteer's Avatar
Jupiter , Florida
On trailers as old as ours its a modified asphalt, example: The frame paint on mine was a waxy asphalt with a little creosote-like properties kicker BUT for the '73 I have the pink contact adhesive sprayed on (major repair/rehab sometime?).
You might try one of the semi-gel strippers with a sheet of polyethylene cover to keep it from evaporating and letting it sit XX minutes X hours etc until the base layer softens. Can you get remote sourced air and a 110% spark-less workspace for the duration?
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 06-17-2011, 10:55 PM   #3
Darkspeed's Avatar
1972 31' Sovereign
Thanks Wabbiteer
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
Fiberglass vs Cotton Insulation GeocamperAS General Interior Topics 13 03-09-2011 07:22 AM
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 06:50 AM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
