Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 08-15-2017, 02:21 PM   #1
2013 25' International
Boise , Idaho
Accidentally used steel rivets
I accidentally put two steel rivets (all steel, not mandrel) into some holes where I had some become displaced.
Do I need to remove them? If so, what is the easiest way to do it?
Thanks!
Adam
afk314 is offline   Reply With Quote
Old 08-15-2017, 02:34 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Oh no! You've ruined everything! I'll buy your 25' for $75. That's all it's worth now, and really, I'm doing you a favor.
Actually it's no big deal. Carefully drill them out and replace them. Drilling can get a little tricky as the rivet can just start spinning, but start with a 1/8" bit and go very slightly larger on just the part of the rivet you see (try not to go all the way through).
This has been done a million times before. A few of them by me.
2019 Ford Expedition Platinum
Old 08-15-2017, 03:01 PM   #3
Boise , Idaho
Perfect
Removed and replaced. Thanks!
Old 08-15-2017, 03:34 PM   #4
Wayne&Sam's Avatar
Images: 21
Darn! I almost had an International for $75!
Old 08-16-2017, 02:37 PM   #5
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento , California
No.. leave 'em alone... butg make sure you paint over 'em.. as the electron action of alu to steel.. makes the steel rust.. but most steel rivets... are alloy and along the line of SS steel... so taking 'em out your run the risk of sliding off the steel rivet and damaging the alu it is in... They make a rivet shaver.. but its costly and again you slip and the soft alu is history... I'd leave it alone... and go with it...
GM Airstream is offline   Reply With Quote
Old 08-16-2017, 07:40 PM   #6
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Or 'pot' the rivet heads and 'shop heads' with a suitable waterproofer to keep moisture away. It's the moisture that acts as an electrolyte, that turns two dissimilar metals into a galvanic mess, as said above.
MelGoddard is offline   Reply With Quote
HELP! Accidentally putting E-85 instead of diesel in AI roadmama Sprinter and B-van Forum 66 11-29-2015 05:31 AM
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Steel rivets??? edleeseng All Argosy Trailers 4 09-04-2007 08:20 PM
Polishing tip found accidentally Hank A Cleaning, Stripping & Polishing 7 03-01-2007 10:33 AM
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 06:54 AM
