Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping
Old 11-29-2009, 07:03 PM   #1
1991 34' Limited
Teeswater , Ontario
LCD TVs on the road
My husband and I just bought a 32 inch LCD TV for our Airstream. Only difficulty is, there isn't a place to mount the TV. Only a wooden box that we can contain it in (the TV sits on it when we're stationary). Is it possible to lay the LCD flat on our bed in transit (face up or face down, either under the covers or under the foam mattress topper), or should be keep it vertical on the stand in the wooden box, surrounded by, say, bubble wrap ro something protective?
Any thoughts would be appreciated.
skydiva is offline   Reply With Quote
Old 11-29-2009, 07:05 PM   #2
Retired.
. , At Large
Welcome to the forums.
We have a 21" LCD television that we store face down on the bed, on top of the comforter. It has ridden there many thousands of miles with no trouble.
Old 11-29-2009, 07:06 PM   #3
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
On the Bed is not recommended. The rear bed moves around the most in the trailer. The couch up front is a better bet. Best yet, mount it. I have one TV that has been through two accidents mount to the wall.
Michelle TAC MT-0
Sarah, Snowball
Old 11-29-2009, 08:05 PM   #4
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I used to put the 23" LCD on the bed in the rear, face down. It has the mounting hardware for putting it up on the wall so it is heavier than one without and more top heavy when laying face down. Long story short, we went through some bad road repair one time that really bounced the trailer around some. Found the tv on the floor! Now I just put it there, wrapped in a comforter.
I'm a little hesitant on leaving it on the wall, being it is a swing out wall mount and I do not have it bolted through the wall. JMHO.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 11-29-2009, 08:10 PM   #5
2000 34' Limited S/O
Greensboro , North Carolina
I have mine mounted.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 11-29-2009, 08:35 PM   #6
DrPlay's Avatar
2006 25' International CCD
Freehold , New Jersey
I have two on mounts that allow it to quickly hang on or take off the wall (bedroom wall/bolted to inside of closet and behind dinette on same wall as frig). I always remove, wrap in blankets face down on bed asurrounded by pillows, and they have never gone anywhere.
DrPlay is offline   Reply With Quote
Old 11-29-2009, 08:42 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I used to keep mine screenside down on the bed surrounded by pillows. I found it on the floor one time too. Now I put it on the floor between the beds surrounded by pillows too, like Julia & Bob. I do have new Centramatics now & I'm quite sure it would stay on the bed, but I don't want to risk it!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-29-2009, 09:04 PM   #8
"Cloudsplitter"
Thumbs up
We just up-graded to a 32" Aquas this season, thats exactly how we transport, face down on the curbside rear twin, wrapped in a microfiber blanket. The feet on the base set between the mattress and wall.
Never had a problem with it moving around while on the road, it's easy to bring inside if needed and during our sweet Bflo Winters..... LCD's will freeze.
Old 11-29-2009, 09:28 PM   #9
RichHog's Avatar
1972 23' Safari
Houston , Texas
Lcd tv
I have a 22" Vizio that is on rotating arm. We can spin it around to the bedroom and watch in bed or on the Gaucho. During travel I store it in a bin , it barely fits under the bed and wrap in a towel.
Had put a 26" on the bed with pillows and found it on the floor once and that changed that for me.
I'm concerned about the theft side of it which is why it gets packed up and put away out of sight.
RichHog is offline   Reply With Quote
Old 11-30-2009, 08:04 AM   #10
Cantrell's Avatar
1985 34' Limited
1960 24' Tradewind
Summerville , South Carolina
SkyDiva,
32" is a large TV. Maybe you could post a pic or two of your interior and the great minds here could offer advice on a permanent mounting location??? Mounted on a box seems like an invitation to trouble sooner or later.
When we are rolling, we wrap ours in a blanket and let it ride in the slide out drawer beneath the gaucho. It does seem best to keep fragile items toward the front of the trailer during transport--a lot less bounce.
Good luck,
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 11-30-2009, 08:28 AM   #11
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
We travel with LCD TV face down on the bed so far no problems.
Garry
Old 11-30-2009, 09:00 AM   #12
"Cloudsplitter"
As noted on our last post, this works for us...
May not apply to others, you can see how the feet on the base fit between the bed and the wall, stays put good....
Name:	Aquas on 'da bed 001.jpg
ID:	91797   Click image for larger version
Name:	Aquas on 'da bed 002.jpg
Old 11-30-2009, 11:43 AM   #13
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Obviously it's not going to move with that whale holding it down
Stephanie
Old 11-30-2009, 12:40 PM   #14
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I suggest using a microfiber towel against the screen if you wrap it in something as other fabric can scratch the LCD screen. Ours was factory mounted on the wall and stays there.
Check the info that comes with the TV about freezing. Our Samsung says, if I remember, -4˚ as the lower limit.
Perhaps the safest place is the tow vehicle. In an extended cab, the space behind the front seats probably is the least bouncy place since it's right between the axles and you can stow it there between the seats.
Gene
Old 11-30-2009, 02:03 PM   #15
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I wrapped our LCD in one of my Polartec fleece pullovers and laid it on the bed until I could reposition the wall mount to accommodate the larger sized TV set. It worked just fine. Here's something that some of you may be interested in that I saw at IKEA this weekend. It's lightweight, rather inexpensive, and made (mostly) out of aluminum, which would look good in any Airstream.
IKEA | TV solutions | TV solutions for flatscreen TVs up to 37" | OBSERVATÖR | Wall mounted TV stand
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 11-30-2009, 02:22 PM   #16
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Hi Sky,
What you could do is have a straight mounting post made that would fit in the cabinet space bolted at the bottom and top. A Peerless swing arm mount would allow you to pull the TV out of the cabinet and swivel to the desired viewing location. I had a gooseneck version made to support my 32" LCD from the website listed below using the 4"x4" baseplate at both ends.
PedestalCEO® - Gooseneck, Security & Access Control Pedestals
Here is what I did.
Name:	32 Insignia LCD DVD 3.jpg
ID:	91820   Click image for larger version
Name:	32 Insignia LCD DVD 12.jpg
Name:	32 Insignia LCD DVD 7.jpg
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 11-30-2009, 02:35 PM   #17
JimW's Avatar
1997 30' Limited
Omaha , Nebraska
We store our 28in LCD on the front couch, covered and screen-side up and it has never moved. The rear bed room is the harshest riding area according to my observations and moveable items move forward, ie off the bed, if the brakes need to be set hard. The couch is also close to the credenza where we set it up to watch.
Rig: '97 30' Limited
Towed by: '19 Silverado 2500 Duramax
WBCCI #22116
JimW is offline   Reply With Quote
Old 11-30-2009, 03:29 PM   #18
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I agree, My philosophy is to store delicate things on teh lowest level to which they might otherwise find there own way! We have always carried tv's on the floor.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-30-2009, 07:17 PM   #19
nynick52's Avatar
1973 Argosy 24
Adrian , Michigan
Ours is wall mounted with a swing arm to watch it from the side bed or from our recently completed front dinette. We have a bungee cord mounted to the wall behind the TV and pull it to the wall and wrap the bunge to it. This gives it a slight play (willow vs oak) and has travelled very well.
Nick
nynick52 is offline   Reply With Quote
Old 11-30-2009, 09:28 PM   #20
PLDodd's Avatar
1975 Argosy 26
Portsmouth , Virginia
I mounted a 19" to the end of the streetside overhead cabinet facing the gaucho sofa. I used a 4 way tilting bracket that will extend around the corner and face the curbside (my wifes) bed. (she likes to watch tv at night, I don't need it to fall asleep) Also it will extend toward the door so sitting outside under the awning I can watch the game (Roll Tide!) I used a strap, riveted to the ceiling behind the tv that holds up the tv and also keeps it from extending while traveling. I notoced the new AS trailers have a strap also. Works for me. I bought my tv from target, 19" was the lightest one on the shelf and the controls are on the left side looking at the screen. Dvd player is in the the overhead above the sofa. 8 hr road trip, all is well.
PLDodd is offline   Reply With Quote
19' CCD owners with LCD TVs that you mounted ericwarren Audio, Video & TV 19 11-28-2011 06:10 PM
Flat Panel TVs MikeF Audio, Video & TV 113 05-20-2010 06:05 AM
Flat screen TVs and cold weather Antique Pedaler Winterizing, Storage, Carports & Covers 5 10-10-2009 06:16 PM
Changing TVs and switching wd hitch arms to new TV WyoRacerX Hitches, Couplers & Balls 3 06-16-2008 07:34 AM
06 versus 07 Diesel TVs Streamer1 Tow Vehicles 24 11-22-2006 06:38 AM
