01-24-2013, 09:20 PM
#301
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
01-25-2013, 03:57 PM
#302
Master of Universe
2008 25' Safari FB SE
Grand Junction
Originally Posted by Ronman
I needed one today since we are going out tomorrow. Has anyone changed out the filtration system with something better?
Thanks AS Brethren!
You are probably gone by now, but in ours I believe the filter is only for the small faucet that provides filtered water, so you don't have a big problem. I think when the filter is removed, a valve closes and water cannot leak out when you turn on the small faucet to the right of the regular kitchen faucet.
Gene
01-25-2013, 06:52 PM
#303
East Tawas
, Michigan
Found out the hard way,don't leave wine in the AS when Michigan winter temps drop below zero. If it wasn't for the broken glass I could have had a wine- sicle.
01-29-2013, 12:42 PM
#304
2007 27' Safari FB SE
Rancho Murieta
Gene,
Thanks for this. I just capped off the supply for the trip last weekend. Yes, the filtered water is only for the small tap. Having something that shuts off the suppply when the filter is removed makes sense.I will try it in a couple of weeks and report back.
Thanks again!
Ron
02-01-2013, 09:09 AM
#305
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
A Wine-sicle, now that's an idea for a hot summer day. Hmmmmmm need to think on that one.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
11-09-2013, 10:10 AM
#306
1991 29' Excella
Tulsa
, Oklahoma
Okay, I am sooo confused...
We live in Tulsa, OK and there is some really cold weather coming next week. We had planned on having a service come out to do the first winterization, but after reading my "Newbies Guide to Airstreaming" we decided to just do ourselfs...
Now after getting knee deep both here and on the internet on the how to's, I think I might have made a mistake. My questions are:
-do we really need to blow out the lines if we are just going to fill them with antifreeze?
- do I need to put antifreeze in the holding tanks or just drain them?
A little background.. This is our first winter with the AS and I am planning on using it in two weeks for some winter camping, so we will be doing this more than once this year. Our winters are usually fairly mild and does freeze for sustained periods. We have it stored in an enclosed metal building, which it probably will dip down below freezing inside.
Thank you so much..
Vickie
11-09-2013, 10:27 AM
#307
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Unless you have a reliable method for draining the holding tanks completely, leaving them bone dry, I'd say best to add antifreeze.
Besides, antifreeze in the holding tanks helps keep the valve seals moist, so you don't come back to leaking seals on your holding tank drain valves come spring.
11-09-2013, 10:41 AM
#308
1991 29' Excella
Tulsa
, Oklahoma
Originally Posted by Protagonist
Unless you have a reliable method for draining the holding tanks completely, leaving them bone dry, I'd say best to add antifreeze. Besides, antifreeze in the holding tanks helps keep the valve seals moist, so you don't come back to leaking seals on your holding tank drain valves come spring.
Thank you P... So just like a gallon in each tank? Also, we are going to Lowe's and pick up an inexpensive air compressor.. I think we can do this!
11-09-2013, 11:41 AM
#309
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
I just blew the lines on our AS last week. Overnight I remembered that I had neglected to do the outside faucet and black tank spray system. So I'll have to hook it up again and finish the job. Glad I remembered before it was too late. Also if you have any filters in the lines you should remove them before pumping any anti-freeze solutions. You will probably want to put new ones in anyhow. So, Just a reminder of a few things along the way. In fact I just blow the lines and put anti-freeze in the traps and toilet. I do not pump it throughout the system. I've never had any problems doing that.
Good luck with your job.
Roger in NJ
TAC - NJ 18
11-10-2013, 01:38 AM
#310
Rancho Murieta
When blowing out the lines, be sure to control the pressure and remove the water filter. The filter does not do well with air pressure. Dick & Vicki...If you are storing your rig inside, you should not have too many worries. Even if it dips below freezing outside and you blow out the lines, you should be OK. I would still put antifreeze in the traps as a precaution. Oklahoma does not get that cold, right?
11-10-2013, 04:40 AM
#311
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
Blowing out the lines and then running antifreeze through them seems a little like belts and suspenders to me. I've never blown mine out, but I do use three gallons of antifreeze. I'll run it through the pump to every faucet, shower, and toilet. I let it run pink/orange out the faucet for a fairly long time. My thoughts are I'm taking care of the drains and tanks at the same time.. So far, no problems, and it doesn't take but a few minutes. (With two of us doing it.)
Am I missing something? Our AS is under a roof, but its not enclosed. We get some good freezes here in Missouri. (Looking at 18 or 19 here on Monday night.)
Jeff
11-10-2013, 08:27 PM
#312
2004 30' Classic Slideout
Fenton
, Missouri
Originally Posted by GettinAway
Blowing out the lines and then running antifreeze through them seems a little like belts and suspenders to me. I've never blown mine out, but I do use three gallons of antifreeze. I'll run it through the pump to every faucet, shower, and toilet. I let it run pink/orange out the faucet for a fairly long time. My thoughts are I'm taking care of the drains and tanks at the same time.. So far, no problems, and it doesn't take but a few minutes. (With two of us doing it.) Am I missing something? Our AS is under a roof, but its not enclosed. We get some good freezes here in Missouri. (Looking at 18 or 19 here on Monday night.) Thanks Jeff
No doubt if you run enough anti-freeze though, you will displace the water and won't need to blow out the lines first. The reason I blow out the lines first is that it takes less antifreeze. The second reason is that to successfully get rid of the water in the pipes between the hot water bypass valves and the tank itself, you have to push anti-freeze into the water tank.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
11-11-2013, 04:52 AM
#313
1991 29' Excella
Tulsa
, Oklahoma
Thanks everyone.. Okay, we had planned on going out to the AS on Saturday, but had company come over and never made it out, when the RV stores where open. So Sunday we headed out, but when we got there we realized we didn't have everything we needed (and couldn't find it at either lowes or home depot) so we didn't winterize.
My husband leaves town for the week this morning and it's up to me to get this done today. It's dipping down to 25 tonight. Grrrrrrr!!
So I think I'll just go to the RV store and buy one of those kits that has the pump for the anti freeze and pump it into the system (closing off and draining the water heater)..
Is this pretty easy for one person to do? Dang, I'm tempted to just pour a little anti freeze down the traps, but I sure don't want any frozen lines...
Vickie (the aggravated wife!)
11-11-2013, 07:45 AM
#314
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
After all is done you should pour some RV AF down into the traps. In fact that's a MUST. But you will also need to do one of the other routines and either pump AF throughout he plumbing or blow with compressed air. Whichever you choose there's plenty of guidance here on the forum. It's a single person job but easier if you follow a routine just to make sure you cover all the tasks. If your water heater has a by-pass figure out where it is and how to use it. It will save you 5 or 6 gallons of RV AF. If you have any filters you should plan to remove them. You will probably want to replace them next season anyhow but they say the AF will ruin them. Don't forget the outside faucet and black tank spray system ( if so equipped ) and low point drains under the trailer. It's not difficult but its a step by step process.
Roger in NJ
TAC - NJ 18
11-11-2013, 08:30 PM
#315
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits
, Michigan
If this link works, I have posted my winterization checklist:
https://www.dropbox.com/s/qab521s8nt...hecklists.docx
Note that it is included with my summarization checklist and my standard departure checklist. Who's anal? Please let me know if there's something that you see that I've missed? This is only my second time doing a winterization, but it took less than 30 minutes once I have the right tools in hand to get the job done:
Compressor
Water inlet pressure fitting
3 gallons antifreeze
Silicone hose and adapter for t-valve
Crescent wrench to remove the water heater drain plug
Hibby
11-12-2013, 08:34 PM
#316
Master of Universe
Grand Junction
Vickie, if you are going out in 2 weeks, just run the furnace at the lowest setting on the thermostat. Keep it plugged into shore power so you won't run the batteries down. That'll keep everything warm enough for the duration and you'll have more time to learn how to winterize. Make sure you have enough propane.
Gene
Gene
11-13-2013, 07:32 AM
#317
1991 29' Excella
Tulsa
, Oklahoma
I want to thank everyone who posted here to help me. Here's what happened. I went out to the AS to winterize on Sunday. I couldn't unscrew the nut to let the water out of my water heater and looking at the pump I felt overwhelmed. There was another man at the storage so I asked him about it. He said not to worry about winterizing since we are only having a hard freeze for one night, that it is warming up during the day and it's enclosed.
I had thought about leaving the heater on, but didn't feel comfortable doing that.. Anyway, there was only a hard freeze for a few hours so I'm keeping my fingers crossed. This weekend we'll get this winterizing all figured out, so we won't go through this again!
02-23-2014, 05:40 AM
#318
2007 27' Classic FB
Myrtle Beach
, South Carolina
John:
Is the 'diverter valve' the valve that bypasses the water heater?
"The Percolator"
02-23-2014, 06:14 AM
#319
2013 23' International
Penfield
, New York
Originally Posted by golfarch
John:
Yes, generally speaking however I would recommend looking at your AS manual. I had some difficulty locating the "winterizing" valve, even studying the manual. Hope these pics help.
02-24-2014, 04:17 AM
#320
2007 27' Classic FB
Myrtle Beach
, South Carolina
John:
What does the first photo indicate? In the second photo, is the valve the mustard color item that is parallel to the pipe located on the floor? Finally, is the 'Winterized' graphic located on the water heater Styrofoam?
"The Percolator"
