05-28-2015, 02:39 PM
1973 31' Sovereign
Austin
AS metal carport type storage
just got my 1973 31ft AS polished up and need to have a metal carport type storage cover to protect it.
What size do I need to make sure it is protected from sun, hail, etc. ?
What length? 36 ft?
What height ? 12ft?
Width ? Would 14 ft allow me to open door and access inside AS?
Thanks for any advise
05-28-2015, 02:45 PM
Biloxi
, Mississippi
Longer, higher and wider than your trailer. Room to work around all sides and on top. Bigger the better.
MICHAEL
05-28-2015, 03:56 PM
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach
That Airstream deserves its own castle, in my view. Wow! That is beautiful! Congratulations. Joe
05-28-2015, 03:58 PM
irving
Make it as large as you have space and money for.
05-28-2015, 10:39 PM
1999 34' Excella
Hillsboro
Ditto... at least 3 feet around all sides.. and the top if you plan to do any work on it yourself. Then, also have 'sides' on it.. at least halfway down from top to minimize Hail damage potential.
Peace and Blessings..
Channing
WBCCI# 30676
05-29-2015, 11:37 AM
2013 30' Classic
Greenwood
, Mississippi
When I get a round tuit I will have a 24' wide x 40' long x 12' high priced in the $3,700 range. Can add sides later. North side against a fence, east side against the house, south side against an existing shed. Maybe eventually a roll-up door on the west end.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
05-29-2015, 12:17 PM
Regular Guy
1978 31' Sovereign
Hot Springs
, Arkansas
That rig belongs in a art museum when you aren't using it. No kidding. I would build a concrete reinforced bunker......
05-29-2015, 01:21 PM
1983 31' Excella
The Woodlands
That shine is great.. Who did it?
05-30-2015, 07:36 AM
Durango
If you have the room, a pull through is the best answer. I have 30 amp service and overhead lights in my Airstream "hanger".
If you don't go first class, your heirs will!
06-07-2015, 08:12 PM
2005 31' Classic
Garner,
, North Carolina
so to get back to the OP question about size.. I did not see anyone with a good answer on his size. the larger building tend to cost more.
I am planning to get a 28 ft unit and was looking at a 18 wide x 30 long by 10 foot sides and was wondering the same thing.. the cost is currently 1705.00 in the above numbers. To go up on side legs to 12 ft tall, the roof goes up
appx 2 or so feet higher than side legs, and the price goes up to $1,855.00.
what is the usual height of a AS unit with AC on top , with up sized tire to 15" size be.
Metal Carports, Garage & Carport Kits - Carport.com
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
06-07-2015, 08:48 PM
1974 Argosy 26
Morrill
, Nebraska
I would go with 12' high to give you room to access the top of the coach. And another 2' to 4' in length to protect the coach from the 45 degree hail storms. If you have them where you live.
06-16-2015, 04:41 PM
2005 31' Classic
Garner,
, North Carolina
What would be the actual height of trailer to top of AC unit?.
The covers side height at 11ft the actual top of cover would be some 3 feet taller in the center of the cover.
We rarely get "hell" around here but the idea is good to be a bit longer to protect the metal for sure.
Carl, Raleigh NC
06-17-2015, 09:56 AM
1973 Argosy 24
Kitchener
, Ontario
YMMV but my 73 Argosy is 10'9" to the top of the AC. My pucker factor at 11' is pretty high.
06-17-2015, 03:14 PM
Wheels Itch)(Must Travel
2014 25' FB Flying Cloud
- east coastal area -
As a side question to the carport size, has anyone dealt with carport.com or any other large shelter supplier? I am also looking to have a good shelter for our AS and it would be interesting to get opinions on who is good.
az-streamer
Jon & Deb
Phoebe & Ellis - The Airstreaming Mini-Schauzers
[CENTER][I]
06-17-2015, 04:48 PM
2004 25' Classic
Prescott
carl2591,
The height with ac on a 2004 according to my manual is 9'-7.5".
Julia & Bob
W/ Deedee & Boo
AIR #30685
06-17-2015, 05:57 PM
1975 31' Sovereign
howell
, Michigan
I went with a 18' wide X 30' deep 10'high , park the AS tight on right hand side and park the F250 tight on the left side, this allows enough room to open the AS door. It is tight but it works, I beleive with the pitch of the roof a 8' tall side wall would also work without issue.
06-17-2015, 06:48 PM
1994 21' Sovereign
The high country. Black Mountain range.
, North Carolina
Our solution. Vertical roof for snow. 12 gauge, certified with 10 foot legs. Arbor anchors.
WBCCI 28499
"Not all those who wander are lost" J.R.R. Tolkien
06-17-2015, 10:14 PM
2005 31' Classic
Garner,
, North Carolina
very nice indeed.
now if you could hitch the boat behind the AS that would be the real deal
Carl, Raleigh NC
06-18-2015, 05:49 AM
1994 21' Sovereign
, North Carolina
Originally Posted by carl2591
very nice indeed.
Thanks, and you are correct. However, I do have the canoe loaded on the TV.
WBCCI 28499
06-18-2015, 08:49 PM
Durango
My Airstream "hanger" (see post #9) is 18' wide, 30' long and the opening is 12' tall. AS is a Safari FB 25'.
