Old 03-30-2011, 08:13 AM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Window seal leaking ??????
I guess it's my turn for the age old ( or Airstream Old ) issue of leaks. It seems that just to the right of the entry door is a non-opening window. It originally was a double paned one but someone in it's prior life had removed the inner pane. Probably due to its inner seal leaking and the window fogging. That's another story. On the outside there seems to be a piece of aluminum trim that's rivited to the body with a seal of some sort to make it weather proof. I see some gaps in the glass / seal line and they are significant and need to be sealed. I have some sealer that I used on the roof when I installed new vents. Is that good for the window application or is there something more appropiate I can use. The original seal between the glass and trim appears to have been a solid material rather than a caulking type. It has leaked onto the floor and will require me to remove some of the flooring and replace. But that's another thread and issue.
Thanks all,
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 03-30-2011, 10:36 AM   #2
retired USA/USAF
2001 30' Excella
Thanks to Andy. My question seems to have already been discussed and answered.
Roger in NJ
TAC - NJ 18
Old 03-30-2011, 03:58 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
I don't know about the glass seal, but I replaced all the window gaskets on my trailer. Some of those leaked and they were all brittle, compressed, and checked.
Click on the link to see a picture of the Sioux River falls near my home.
https://visitsiouxfalls.com/assets/i...uxfalls-og.jpg
Eastern South Dakota is very pretty with hills, rivers, and trees.
Splitrock is offline   Reply With Quote
Old 03-31-2011, 07:26 AM   #4
retired USA/USAF
2001 30' Excella
I think it's a good idea to replace them all to do a complete job. My need now is to seal off an existing leak that has destroyed my floor so I can clean things up and repair the floor. It seems that the glass seal for these non-opening windows are not available. The gaps I had were not large but significant enough to have to be closed. I followed the instructions given by Andy for a different thread about the same issue so I hope that I have at the very least stopped the water entry from this source. Now on to removing the floor and replacing it.
Thanks for the input.
Roger in NJ
TAC - NJ 18
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 16 01-14-2022 01:42 AM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
Got my window out. Now what? Breadbug Windows & Screens 3 01-23-2011 07:27 PM
