Old 01-02-2010, 12:10 PM   #1
1999 34' Limited
Amite , Louisiana
sealant replacement on roof vents
How do I remove the old sealant from vents and what sealant is best for replacement?
WallyO is offline   Reply With Quote
Old 01-02-2010, 03:00 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Try Gum-out carb cleaner - it really depends on what the sealant on there is for removal.
Vulkum is what Chris says he'd use for re-sealing. AKA: TemPro. Avoid silicone like the plague - it reacts with aluminum!
Kay
Old 01-04-2010, 08:57 AM   #3
"Cloudsplitter"
Thumbs up
This is what I used when repairing the black water vent, The Westleys worked really well in cleaning the gummy stuff, acryl-clean for softening and final wipe down. A wooden paint stirrer worked well for scraping the old gunk off, no scratching.
Have Fun.....
Name:	SOLAR PANELS; ROOF LEAK 021.jpg
Sealant for roof vents & skylight? Dodge Man Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-31-2013 06:43 PM
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
Roof sealant Nightwind15 2005 and newer - Bambi all models 3 11-05-2008 08:45 AM
White Roof Sealant on Newer Airstream clancy_boy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 02-21-2007 06:32 PM
Installing roof AC. Need a sealant nds Clearcoat, Exterior Paint & Trim 8 07-22-2003 06:33 PM
