Old 07-23-2011, 02:47 PM   #1
2004 28' Safari S/O
pittsburgh , Pennsylvania
Guidelines on where to seal AS TT
I have searched the forums and can not find a general guideline of where to seal the AS.
There are some obvious spots like around the vents or door etc. But what about the seems of the body panels? Or whats under the lower trim molding? How about around the slide?
We have an 04 Safari 28SLD. No visible leaks, but there are some areas that should be done for peace of mind. I know from owning other RV's that they all need this maintenance.
Can anyone help out or point me to a link?
DaKarch is offline   Reply With Quote
Old 07-26-2011, 08:49 PM   #2
1963 19' Globetrotter
Old Bridge , New Jersey
I'm a new owner of an old A/S, I do have a couple of leaks that I have to fix. My question would be, why fix what ain't broke ?
njloco is offline   Reply With Quote
Old 07-27-2011, 07:39 AM   #3
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
It's always best to fix a problem before it gets really bad!!
By fixing the water leaks early ,this hopefully will prevent major frame repairs.
Even if you need to do these repairs, remember your not alone.
This forum has people who are obssessed in a good way , to provided help ,
guidance and direction.
Welcome to the forum!!!
william Haym is offline   Reply With Quote
Old 08-01-2011, 06:52 PM   #4
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
I only wish my PO worried a little about "what should be done"... Good for you DaKarch!
captmatt is offline   Reply With Quote
Old 08-01-2011, 07:05 PM   #5
"Cloudsplitter"
"if it ain't broke.....fix it 'til it is"
Just what I do..keep an eye out for signs of a leak and fix as needed.
Climb up top and check the black tank vent, FF covers, antenna's and skylight if you have one.
I've repaired them all
Found this our first Season...
Name:	SOLAR PANELS; ROOF LEAK 011.jpg
Old 04-16-2012, 11:15 PM   #6
2004 28' Safari S/O
So I thought I would post an update.
1st. Get on the roof! We used the padded ladder method and stand on rivets.
2nd The reason you do preventative rather than reactive maintenance!
3rd I decided to use Acryl R with applicator, Sikaflex (white and black). Seal roof items (vents and antennas) , bottom drip edge, around door handle, outside lights, marker lights and roof drip edges.
Old 04-18-2012, 04:50 PM   #7
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Thanks for the photos. Always helpful. We are getting ready to do the first one night shake-down outing in our formerly very leaky '86 AS. I did have to seal bottom trim around a dent left by PO and likely cause of a small soft spot in floor to be addressed at a later date. Another thing that helped us with the daily driving summer rains was sealing the seams and rivets with some of Capt. Tolley's creeping crack cure. One little bottle goes a long way if you do it right... makes clean up easier too.
Old 04-18-2012, 07:29 PM   #8
Splitrock's Avatar
Sioux Falls , South Dakota
Fixed your link for ya.
Capt. Tolley's Creeping Crack Cure
Dometic Fridge Seal swainee Refrigerators 1 08-30-2011 12:17 AM
seal & repair roof joelbert Roof 3 07-10-2011 03:40 PM
VIN doesn't match Airstream guidelines casa3805 Title, VIN & Registration 1 04-02-2011 12:49 PM
Window seal leaking ?????? polarlyse Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 03-31-2011 07:26 AM
Will gasket material seal the rear bumper storage? tvanwave Bumpers & Bumper Storage 0 01-31-2011 04:00 PM
