Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 04-15-2006, 11:33 PM   #1
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
Looking to repair windows
Where can you get the weather stripping for the window and doors for the 75 a/s sov.I replaced all the screens last night .and,thats when noticed they need it to be replaced.I also need the ones for the window latch.The thing that window level ride up and down on to keep the window opened
Angel73 is offline   Reply With Quote
Old 04-16-2006, 05:03 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Check here, Vintage Trailer Supply
They have a ton of stuff! Or you can order through an Airstream dealer if they do not have it. I got my door seal and window seals from Oasis RV
However Vintage Trailer has since started stocking quite a few seals.. G'd Luck
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-16-2006, 05:11 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Angel73,
I got mine from my "local" Airstream dealer. They have been in business since the 60's. But apparently the 70's vintage weather stripping is still readily available. I would buy the glue from somewhere like NAPA...quite a bit cheaper than the AS dealer. Make sure you get the surfaces very clean, I used a brass brush in my drill to get all of the old sealant off.
Aaron
WBCCI #XXXX AIR #2495
Old 05-11-2006, 06:18 PM   #4
Angel73's Avatar
1975 31' Sovereign
Images: 65
Well
Thanks guys ill do that....
The Clark Family
Old 05-11-2006, 08:05 PM   #5
Naples , Florida
3M Weatrherstrip adhesive in the red tube from NAPA is bomb-proof for attaching rubber to metal. Follow the directions EXACTLY!
lewster
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Windows Inland RV Center, In Windows & Screens 1 04-20-2004 06:14 AM
Caravel windows susan martin 1966-68 Caravel 1 08-21-2002 08:43 AM
M/H Windows uncleneal Mechanics Corner - Engines, Transmission & More... 6 08-04-2002 01:34 PM
