Where can you get the weather stripping for the window and doors for the 75 a/s sov.I replaced all the screens last night .and,thats when noticed they need it to be replaced.I also need the ones for the window latch.The thing that window level ride up and down on to keep the window opened
Check here, Vintage Trailer Supply
They have a ton of stuff! Or you can order through an Airstream dealer if they do not have it. I got my door seal and window seals from Oasis RV
However Vintage Trailer has since started stocking quite a few seals.. G'd Luck
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
2007 GMC Sierra 2500 HD Duramax
WBCCI 1754 - AIR # 6281 www.balrgn.com
Angel73,
I got mine from my "local" Airstream dealer. They have been in business since the 60's. But apparently the 70's vintage weather stripping is still readily available. I would buy the glue from somewhere like NAPA...quite a bit cheaper than the AS dealer. Make sure you get the surfaces very clean, I used a brass brush in my drill to get all of the old sealant off.
Aaron
WBCCI #XXXX AIR #2495
3M Weatrherstrip adhesive in the red tube from NAPA is bomb-proof for attaching rubber to metal. Follow the directions EXACTLY!
lewster
