Originally Posted by 59er
I'm needing a picture for reference.
the PO of my 64 overlander butchered the striker opening of my door. I could use a picture of that part of the door (on the door edge, where the striker protrudes). not the catch plate on the door jamb.
I've fixed my door knob several times and I'm reluctant to order a new knob and have it fail the same way. the inside washer that's bradded on to the outside knob/shaft keeps popping loose.
has anyone had this happen to the replacement knob sets (bargman L100)?
Thanks.
You can end your door lock troubles by installing the entrance door lock that was used from
1966 to 1969.
You would need to add a small plate to the inside and outside of the door, which is not a biggie.
